It is currently Thu May 15, 2025 10:35 am
PostPosted: Wed Nov 17, 2010 11:01 am
Anyone tell me where i can get these - new or used - Honda Service says part has been doscontinued?
Thanks.
PostPosted: Wed Nov 17, 2010 11:08 am
upper arms? or lowers???
PostPosted: Wed Nov 17, 2010 11:18 am
both - arent they the same part?
PostPosted: Wed Nov 17, 2010 11:33 am
Are you wanting part 8 in the picture? if so Hoser has a great thread here somewhere - I can't find it - where he straighted the control arms and welded an angle iron them. What is wrong with yours?
PostPosted: Wed Nov 17, 2010 11:59 am
yes part #8 - i have bent mine and straightened it too many times - so i am buying new ones for both sides.
ATV Racing does not list them on their website but I called them and they said they had the stock part - waiting to hear back for confirmation.
PostPosted: Wed Nov 17, 2010 12:03 pm
they will have stock parts that are take-offs, or even ones with hiems on each end... still will want to "hoserize them by welding a small piece of angle iron on them to deflect rocks etc...
PostPosted: Wed Nov 17, 2010 12:35 pm
I had the ends cut off mine and a chromolly tube welded over the ends... after 5 years they are still straight as an arrow.... plus they look way better then welding on the angle iron (sorry Hoser). I did the same with the tie rods.
PostPosted: Fri Nov 19, 2010 12:53 pm
Why you need them, yours damaged or need them for a build. The #8 is front and rear not top and bottom there both the same. Is 8 all you need. I ask because fixing them is easy as DC noted and for a build there other options.
PostPosted: Fri Nov 19, 2010 12:57 pm
I am in need of a pair of the UPPER arms... So I can hack them up like ADNOH has done...
PostPosted: Sun Nov 21, 2010 9:40 am
Seller TNTDEALTZ on Ebay always has them, his is pricey but if you need them badly he will have them, bring the check book though.He ain't cheap. :-)
PostPosted: Sun Nov 21, 2010 9:51 am
I prefer to keep my money in the POOA community!!!
PostPosted: Sun Nov 21, 2010 12:54 pm
Yo Turbo do not buy any yet. I'm working on a set the does away with the stock parts. It will have hiems at all three points. The upright connection is a fixes joint but will be adjustable and replaceable. This will allow one to roll the upright from stock to back 2. It will take the rear from plus 2 to plus 4 on each side. This way no matter where your ride you can adjust the balance and track width. It will only accept a max 14" travel shock. You can still get the arms and cut if you want. They will allow for a nice 12" travel package. Once I have a set built I will build the jig if you want to borrow it. My welding sucks so you will have to do your own. Now if some one has a damages set of arms they would be a good candidate for hacking. I've logged the I-rod and radius rod lenghts fo the jig I posted. If memory sevres me right the assemblyis only 28 lbs Have to go out and check notes on that. Too many numbers in the head.
rear assembly.JPG [98.57 KiB]
Downloaded 122 times
Resize of IMGP6986.JPG [97.08 KiB]
Resize of IMGP6987.JPG [88.79 KiB]
Resize of IMGP6989.JPG [79.52 KiB]
PostPosted: Sun Nov 21, 2010 6:40 pm
No need to apologize many ways to skin a cat and we would like to see them all, thanks for sharing with us what works, I use the angle because its fast, available and my favorite CHEAP lol
Here is the link to my hoserized rods
http://pilotodyssey.com/PO/viewtopic.php?t=1757
PostPosted: Sun Nov 21, 2010 7:32 pm
oooooh ooooowe... something is wrong with these pictures...
no red and whites???
PostPosted: Mon Nov 22, 2010 3:41 pm
Sorry Turbo, it was setting on shelf above the pics. A few more this week and I may get creative or reckless however a person wants to look at it. I sure wish they had blue in the can since it not owned in the US anymore red and white it is.
