Hey Fellas,
Tme to clear out some parts...I am continuing to clear out extra spare parts that are not needed, and or I no longer have a use for them in my shop or current projects. Here is a list of parts and prices. If you need something that you do not see on this list feel free to PM me and I will see if I may have it tucked away somewhere. If you see the items on this add then that means that they are still available. I will remove them as soon as the sale is finalized. I will also add other parts as I come accross them. Please do not be a tire kicker and if you do not have anything positive to say then please hold it to yourself out of respect. If you have any questions please feel free to ask or PM and I will do my best to answer them all in a timely manner. Thank you all in advance. All items highlighted in
RED have been sold and are no longer available.
1. Stock FL350R Air box top lid and bottom with stock air filter -$100
2. Reed cage with boyseen reeds - $50
3. Uni 2 stage filter that can clamp to a carb - $10
4. FL400R ATVR ported cylinder - Must be resleaved - $505. FL400R Front Right (looking at from front) - $100
6. FL400R Left Rear (looking at from rear) - $100
7. 38mm Mikuni nearly complete - $50
8. FL350R K&N new - $25
9. Straight good condition silver Renthal 790 bars which are the CR Mid Bend 7/8 in size with cross bar pad - $2510. Tires - Complete set of front and rear nearely new - Ridden on for 3HR ITP Sand Star front 22x8x10 and rear 22x11x10, still have dimples - $220
11. Brand new K&N for Fl350R - $25
12. FL350R Rear Works performance shocks AT Steelers, Non Resi- $38513. Left Stock front upper and lower J Arms - $75
14. Right Stock front upper and lower J Arms - $75
15. Stock front Left brake drums and spindle with new pads -
16. Stock front Right brake drums and spindle with new pads -
17. FL350R EEE Pipe and silencer - $22518. Stock FL350R pipe - $60
19. Stock FL350R silencer - $40
20. Stock FL350R seat belt - $35
21. Excellent condition FL350R seat $185
22. 2 Excellent condition FL350R axles $200 each
23. Stock pre recall FL350R head - $40
24. Read cage with built inn stuffer, reeds are boyseen - $50
25. Stock FL350R fuel tank that has already been dip cleaned and resealed - $160
26. Stock pair of front FL350 shocks - $50
27. 102 C clutch for FL350, only used on 4 rides - $300
28. Stock 1989 FL400R pipe and silencer $160
29. FL350R top intake air duct - $25
30. Set of rear ITP wheels for FL350/FL400 – Damaged but fixable
31. Used but in good condition OEM FL350 belt - $20
32. Used but in good condition FL350 Carlisle Hypermax belt - $20
33. Fl350 OEM skid plate - $45
34. FL350 ignition box CDI (Capacitor Discharge Ignition) - $11535. FL350 drive cover - $30
36. Fl350 camber link set $45
37. FL350 mirrors with boots - 4 available - $40 each
38. FL350 air guide scoops left and right - $80
39. 2003 Honda CR250R fuel tank with cap - $20
40. FL350 front arm brackets - $25
41. FL350 used complete OEM front brake lines - $30
42. Mikuni 38MM TMX - $90
43. 102c cam weights New complete set 58gram -$30
44. 102c cam weights New complete set 60gram - $30
45. Comet 102c Purple spring -$20
46. Comet 102c Pink spring - $20
47. Comet 102c Red/Blue spring - $20
48. Partial Heel Clicker Adjustable Clutch Kit for 102C– 1 of the cam arms will have to be replaced - $75
49. FL350R stock cylinder bore excellent condition - $250
50. FL400R Stock Intake duct and tube , 2 available - $35
51. U shapped shoulder harness blue - $30
52. 2004 Chevy Duramax HD stock air intake with filter and ducting - $70
53. FL400R/FL350R stock intake in very good condition. No cracks ready to bolt on and go- $40 shiped54. Clarion ADZ625 Cassette/tuner/CD player - Came out of my Denali - $120 shiped
55. Mikuni choke kit New condition - $25
56. FL400R OEM seat harness shoulder pad - very nice condition - $55
57. Brand new Safety Racing wrist restraints - $35 Shiped
Attachments: |
