PilotOdyssey.com
bringing the PPE back to life
http://www.pilotodyssey.com/PO/viewtopic.php?f=42&t=7859
Page 1 of 2
Author:  Turbotexas [ Tue Aug 31, 2010 10:07 pm ]
Post subject:  bringing the PPE back to life
I started working on the Purple Pilot Eater! I am taking the front end and painting it to match the rest of the odyssey! Hoser sent my motor (( Internal Combustion Engine ? )) back, so I am getting this thing cleaned up!
Author:  Tpreed [ Tue Aug 31, 2010 10:23 pm ]
Post subject:  Re: bringing the PPE back to life
:-) its about time.. this is the odyssey i saw on youtube that made me get into all of this!
Author:  Turbotexas [ Tue Aug 31, 2010 10:43 pm ]
Don't Blame ME!!! LOL
Author:  redskinman [ Tue Aug 31, 2010 11:12 pm ]
keep up the good work :-)
Author:  bugeye59 [ Wed Sep 01, 2010 1:25 am ]
You have a suspension tree? :shock:
Can ya send me some seeds Davo? and some Image still in drought mode here,second driest winter on record.
First day of spring today 1-9-10.
Author:  Turbotexas [ Wed Sep 01, 2010 10:14 am ]
I have no seeds, and as seen I am kinda dry here too... Always use caution when chop sawing near dry grass... lol
Author:  Turbotexas [ Fri Sep 03, 2010 10:19 pm ]
Got it into roller condition today! Pulled the fuel tank for a clean out and the radiator to paint the brackets to stop the rust! I just hope I can remember where everything goes! I think I can I think I can!!!
Author:  rarerat [ Fri Sep 03, 2010 11:29 pm ]
Looking good Turbo.
Author:  mudbogger [ Sat Sep 04, 2010 10:17 am ]
Ahh, nice to see the old girl is back!!! I was figuring on seeing that ride back in saddle, good luck with it Turbo.I'll be sending the plate and nuts out today.
Author:  Turbotexas [ Sat Sep 04, 2010 10:21 am ]
Thanks Mud! I was missing the old girl... There is nothing like your first is there! LOL I still love my Pilot too... (Can't have her getting jealous!)
Author:  Turbotexas [ Sat Sep 04, 2010 1:20 pm ]
Well I got the motor (( Internal Combustion Engine ? )) stabbed! Has anyone ever found a replacement for the rubber cover that goes over the pull start rope? Want to keep stuff out of the mechanism!!
File comment: This end ripped while putting on
File comment: I used heat shrink here on this end, but couldn't find any big enough for the other end?
Author:  victor [ Sat Sep 04, 2010 4:42 pm ]
that really is a 1 of a kind looking odyssey the color's look awesome! is the front gonna sit allmost that high off the jackstand's? just a little weight droop looks mean!
Author:  Turbotexas [ Sat Sep 04, 2010 4:57 pm ]
Thank you! This is up on jacks so the front will settle more once it is on all four, plus the Engine is now it it so it is heavier!
Starting the carb with a 52 slow jet and a 160 main
I pulled a keihen off my kids first cr125r which was a 96! I can't find my notes from before, but the motor (( Internal Combustion Engine ? )) will be all new anyway!
Author:  Turbotexas [ Sun Sep 05, 2010 9:29 am ]
dangnabit... I just found my notes on my jetting from the pilot/ody when I w=switched carbs... I have a 168 in the pilot, so I will change this before I fire her up today!
Author:  Turbotexas [ Sun Sep 05, 2010 6:45 pm ]
ok I have started it, but i have to just barely push the throttle to get it to idle, so I will go up on my pilot jet to a 60
Author:  Turbotexas [ Sun Sep 05, 2010 9:48 pm ]
I didnt have a 60, biggest I had was a 55.. needs a 58 or 60... Got it to barely stay idleing enough to move on to putting the seat back in, go to town for 2 hose clamps I have lost, and then I'll take it for a spin...
I need a 39 pwk carb like I had/swapped into pilot...
Anyone have one for trade???
Author:  Turbotexas [ Sun Sep 05, 2010 10:47 pm ]
All I have left to do is put the seat in, belts on and button up the skid plates and she is ready to ride! I am headed to barstow, and am taking the pilot, just wish I had the chance to take both! I need a different carb, the one off my kids bike won't accept the choke cable because it has the idle control on the choke tab!
Author:  hoser [ Mon Sep 06, 2010 8:55 am ]
Whats going on in Barstow?
Heat cycle the Engine yet?
Author:  Turbotexas [ Mon Sep 06, 2010 9:03 am ]
3-4 times while playing with carb putting seat in for heat cycle ride! Nothing. Going on in barstow, just a load to the base out there!
I can't see the buttons on my blackberry well enough lol I had to come back and edit
Author:  Turbotexas [ Mon Sep 06, 2010 11:53 pm ]
Well I drove the PPE around the place a little today. First thing to do when I get back is to fix the brakes! I guess sitting all that time they went bad on me... I have spare pads so it should be an easy fix... Then I need a battery... Again after so long it too was shot... Then I will need some bigger jets. I didn't have enough pilot jet, but I shut the air screw down to one turn out and she wasn't so hot on the digitron. I tried putting the stock carb back on, but the elbow is stretched to much, so I will have to make this carb work for now...
I think I have the turning set up a lot better, almost as tight as the pilot on my little track around the yard. I will know more when I can get it stopped LOL
Author:  lc4 [ Tue Sep 07, 2010 4:07 am ]
Hey Turbo I`m a bit worried about your toolkit as all I can see in some of the pics are hammers :shock: :shock:
Author:  hoser [ Tue Sep 07, 2010 6:26 am ]
that's to tune the front suspension :shock:
Author:  bugeye59 [ Tue Sep 07, 2010 8:50 am ]
Leave Turbs alone you Blokes! Image
Davo here's some ol moves to use at Hammertime Mate!Image
Author:  Turbotexas [ Fri Sep 17, 2010 4:02 pm ]
pulling the pwk out of the pilot to try on ody I had a 162 main, 45 pilot/slow jet...
Author:  Turbotexas [ Fri Sep 17, 2010 4:16 pm ]
starting the ody with a 48 slow and 170 main...
https://www.phpbb.com/
