Joined: Fri Jan 12, 2007 2:17 pm Posts: 3632 Location: Wichita ks
Though I would share a PDF of my Head spreadsheet. Hopefully this will help explain some of the work done to a head. This can be used for center or offset. I also have one for a two and three angle as well. The single is much simpler to understand. You can use this to formulate your own if you wish. By getting a base line than one can change the numbers to get a target before working on it or what change is needed for over bore. This ties into the CCR work sheet so one can see change in CCR or achieve a target number.
Remember this is just stuff I make up so I can not guarantee any thing from it. Just Backyard Hacker stuff.
Attachments: |
