PilotOdyssey.com
Head Area,Volume and Angle
http://www.pilotodyssey.com/PO/viewtopic.php?f=43&t=11943
Page 1 of 1
Author:  adnoh [ Sun Mar 31, 2013 8:01 pm ]
Post subject:  Head Area,Volume and Angle
Though I would share a PDF of my Head spreadsheet. Hopefully this will help explain some of the work done to a head. This can be used for center or offset. I also have one for a two and three angle as well. The single is much simpler to understand. You can use this to formulate your own if you wish. By getting a base line than one can change the numbers to get a target before working on it or what change is needed for over bore. This ties into the CCR work sheet so one can see change in CCR or achieve a target number.
Remember this is just stuff I make up so I can not guarantee any thing from it. Just Backyard Hacker stuff.
Head work Area,Volume and Angle-signed.pdf [327.04 KiB]
Downloaded 199 times
https://www.phpbb.com/
