It is currently Fri Apr 26, 2024 8:11 pm
 Post subject: fun times in garage
PostPosted: Sun Apr 14, 2013 9:57 pm
I had posted some discussion on rppjr Engine so I thought I would go take some pics and video to go along with my ramblings. I mocked up an Engine with out the cases to show the working in degrees of rotation and crank angles. I also took pics of the bench comment of the pilot cylinder. I also took pics of the OEM crushed head gasket. I then took pics of the piston in the cylinder with the cylinder spaced and decked. I even decided to share some pics on the flywheel in degrees as well in relation to the (T) and (F) mark and the piston position. You can see the crank angle as well. Did more however this all I had time to post.
Enjoy the pics and video.
 Post subject: Re: fun times in garage
PostPosted: Sun Apr 14, 2013 10:00 pm
more pics
PostPosted: Sun Apr 14, 2013 10:03 pm
more back yard hacker pics and vids
PostPosted: Sun Apr 14, 2013 10:12 pm
that's some cool stuff,thanks for sharing.
But the real question is ...how friggin big is that calculator in the backround!? :-)
PostPosted: Sun Apr 14, 2013 10:34 pm
That is my garage calc I work on my engines with. My eyes are getting bad so I need big numbers and big keys. I use it on every thing. Best darn Christmas present I ever got. It scares most when I break it out and start using it.
Glad you enjoyed them.
PostPosted: Mon Apr 15, 2013 12:19 pm
Nice, brings a lot of what you have been talking about into perspective. Nothing beats pictures.
Thanks for sharing.
Bob
