It is currently Mon May 19, 2025 11:26 am
PostPosted: Wed Oct 21, 2015 2:42 pm
After reading a few threads on here I decided that I wanted to upgrade the front brakes. I sourced TRX450 uprights + associated parts (not easy as I am UK based), had to also buy new wheels to fit over the TRX brakes.
The brakes are now 10x better - can't wait to take it out for a serious play.
ImageIMG_2618
ImageIMG_2603
ImageIMG_2607
ImageIMG_2604
ImageIMG_2608
PostPosted: Wed Oct 21, 2015 3:08 pm
That's a sexy set up.
Looks like those brakes will stop a F1 car.
On a side note why does your main roll bar only have one bolt on each side holding it ?? :shock:
That's very dangerous in my opinion.
PostPosted: Fri Dec 11, 2015 11:26 pm
Are you still using the stock a-arms and ball joint with those trx uprights and hubs? It was mentioned to me that without modifications adding the trx items would leave the tires off camber like \ /.
PostPosted: Sat Dec 12, 2015 5:49 pm
I you look close he has n adjustable upper balljoint at the very least
PostPosted: Sun Dec 13, 2015 3:54 am
I see that now. I wonder if he just modified the stock arms because they look very similar.
PostPosted: Sun Dec 13, 2015 3:05 pm
Probably exactly what he did. Would not be too difficult to accomplish as long as you get everything set up straight
