It is currently Thu May 15, 2025 8:40 pm
 Post subject: FL250 Stator Specs
PostPosted: Mon Apr 03, 2017 8:11 am
Hello team, I recently bought a 1979 FL250, point system. How do I check if the stator is working? What should the resistance be, there are yellow and black lines coming out of it?
 Post subject: Re: FL250 Stator Specs
PostPosted: Mon Apr 03, 2017 3:12 pm
I don't know to much about the FL250 but you can get a free manual here:
https://oddatv.com/wp-content/uploads/2 ... Manual.pdf
PostPosted: Mon Apr 03, 2017 3:23 pm
You can also use the search box on the top right of this page.
In the search box type ONE word only and hit enter. If you don't you will get to many hits.
In that box type ONE word only. Keep doing this as many times as you want until you have narrowed it down. Some common words will be ignored like "Engine" "Honda" etc.
PostPosted: Mon Apr 03, 2017 3:24 pm
You will also need to know if it is the 6 volt system or the 12 volt system.
The year of your machine will tell you.
PostPosted: Mon Apr 03, 2017 4:58 pm
Every FL250 owner should read Bills Tips http://www.pilotodyssey.com/billtips.htm when you get a chance.
PostPosted: Mon Apr 03, 2017 7:47 pm
Hoser, thank you! lotta helpful tips.
I am guessing mine is a 6V AC system, since it is a 1979.
