It is currently Thu Oct 31, 2024 9:02 pm
 Post subject: H E L P!!!!!!!!
PostPosted: Sat Mar 10, 2012 1:15 pm
I am getting ready to split the cases on my 89 Pilot due to reasons beyond my control. I am in serious need of the crankcase gasket and a seal 42x65x11. Does anybody know where I can get these?
 Post subject: Re: H E L P!!!!!!!!
PostPosted: Sat Mar 10, 2012 1:41 pm
If your going to split the bottom end you need a complete Engine gasket kit
viewtopic.php?f=2&t=5526
The seal your looking for is the right side crank seal?
OIL SEAL (42X65X11) 91203-HE0-003
Been a lot of discussion about this seal
https://www.google.com/search?q=style+g ... 24&bih=583
PostPosted: Sat Mar 10, 2012 1:46 pm
If you split the crank cases you need to replace the crank bearings their has been a lot of discussion about these bearings too
Pressing the cases apart puts the force required against the bearings balls and races and damages the bearings, bearings were not designed for these types of thrust loads.
If you follow the service manuals instructions and methods of installing the new bearings then you put no stress on the balls when you reassemble the cases and bearings.
All kinds of Pilot Engine rebuilds and CSI's on this site to get tips and tricks from when rebuilding a Pilot Engine.
PostPosted: Sat Mar 10, 2012 1:59 pm
Found the gasket kit now I need the seal # 91203-HEO-003. Still in need of one of these
PostPosted: Sat Mar 10, 2012 4:52 pm
Call atvr neil has them
PostPosted: Sat Mar 10, 2012 5:14 pm
Will give him a call on Monday! THANK YOU very much...
PostPosted: Sat Mar 10, 2012 5:23 pm
Do you know if they have the Honda seal or if they are just selling a seal something like this?
http://www.ebay.com/itm/Metric-Oil-Shaf ... 255d28b231
PostPosted: Sat Mar 10, 2012 7:41 pm
Hoser, that seal is NBR (Buna) not Viton. Ids the stock seal Viton? I am in SERIOUS need of one.
PostPosted: Sat Mar 10, 2012 7:52 pm
The mag side seal is all black I have no idea what material its made from maybe LEE knows?
Here are some pictures of the seal. viewtopic.php?f=37&t=9644
The clutch side seal is all black except for where the seal makes contact with the crankshaft and that part is the redish brown color like you see with a Viton seal almost like a insert that is molded into the seal.
I have seen replacement seals for the clutch side that were not Honda seals and they were all black, I have never tried one of these.
PostPosted: Sat Mar 10, 2012 8:39 pm
I personally think ATVR is selling a aftermarket seal, not OEM..
PostPosted: Sat Mar 10, 2012 11:05 pm
Hoser, you will have a first hand look at the aftermarket as I am sedning you 2 left sides and 2 right side crank case bearing seals with for the NITROSPORT Engine rebuild.
PostPosted: Sun Mar 11, 2012 9:46 am
Ok will let you know when they arrive, still have not seen parts from speedchaser yet he send?
PostPosted: Mon Mar 12, 2012 1:06 pm
I ordered both the left and right seals today from ATV Racing. $15.00 each. I will post photos when they arrive. Thank you for the lead. That's why I love these forums.
PostPosted: Mon Mar 12, 2012 11:40 pm
Im sure they are after market.
PostPosted: Sat Jul 27, 2013 2:14 pm
Can you post the pics please
Registered users: Bing [Bot], Duneit, Google [Bot], Q, Rppjr
