FL350 Radiator Mounting Ideas http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=10441 |
Page 1 of 1 |
Author: | (UT)Odyssey [ Thu Jun 28, 2012 9:24 am ] |
Post subject: | FL350 Radiator Mounting Ideas |
I should be installing a water cooled head this weekend. Got a nice Banshee radiator in the mail yesterday from 'Fatcat', thanks again . Looking for some ideas on the best way to mount the radiator. Any tips, detailed pictures would be appreciated. |
Author: | shoubadaba [ Thu Jun 28, 2012 7:46 pm ] |
Post subject: | Re: FL350 Radiator Mounting Ideas |
Ill post some pics for ya of the way I mount the banshee radiators on the odys I build |
Author: | shoubadaba [ Thu Jun 28, 2012 8:02 pm ] | |||||
Post subject: | Re: FL350 Radiator Mounting Ideas | |||||
I use 3/4 x 1/8 aluminum to make the mounts. It bolts to the rollcage in the same holes as the head net.
Author: | (UT)Odyssey [ Thu Jun 28, 2012 9:43 pm ] |
Thank you! If you don't mind, think i'll copy your setup. |
Author: | DMoneyAllstar [ Fri Jun 29, 2012 2:35 pm ] | ||
Yep, do what you can to use existing holes or bolts on the chassis. No sense in hackin' it up. I made the upper bracket that used both L and R brake light / snorkel mounts, and the lower bracket piggy-backed off the top safety harness bolts (in a proper manner, I might add). Made a couple radiator brackets and used some threaded rod to pull it all together.
Author: | (UT)Odyssey [ Fri Jun 29, 2012 9:13 pm ] |
Thanks for posting the pictures Dmoney. Very nice setup! |
