Below is the short story and all most people really need to know about the heads, any more info like "numbers" is 100% total waste of everybody's time, meaningless to 99% that read it, people that would actually understand the meaning of the numbers would not be asking in the first place they would be ordering the head with a blank dome and cutting it to match the
Engine they were building....
For the rest of us all you need to know is the following.
Speedchaser head is more ridged than the stock head eliminates the leaking head gasket problem, when the stock head is pushed to the limits stock or modified it flexes enough to allow the head gasket to lose it seal, Cool head shell is ridged enough it eliminates this problem.
Speedchaser head has the combustion chamber centered in the bore Engine builders all desire this design over the offset dome.
Speedchaser head has a replaceable dome so the owner can change the dome as conditions for them change or if the dome is damaged.
Speedchaser head has a dome that was designed to work really well from stock to fully modified with room left for improvements if owners desires.
Speedchaser head tightens up the squish clearance closer to optimum clearance, stock heads the clearance is way too wide and varies quite a bit from head to head.
Speedchaser head the combustion chamber is machined to 49cc I have found stock heads from 52cc to 56cc, stock heads are high production cast so actually vary quite a bit assume this is why Honda had so much squish clearance to allow for variations in the productions castings, 47cc domes and blank domes available.
Speedchaser head and dome designed to be used with the stock head gasket from stock to 82mm bore.
Other thoughts.
When I bought my first cool head (Duncan brand actually made by Pro-design) I cc'd the head and the area of the head that holds the coolant had more coolant volume than the stock head I measured, I am not implying it cools any better than stock just presenting the facts as I found them.
Before switching to the 'cool head' I kept having problems with leaking head gaskets when I pushed my Pilot really hard, 80+ degree day at the dunes ruining the shit out of my Pilot to the point where I felt the throttle response going away meaning I was right on the verge of boiling over, shortly after the head gasket would leak, going to the cool head fixed this problem have not had a head gasket leak since.
If your Pilot Engine over heats the cool head will not fix this over heating problem , the over heating has nothing to do with your head, your Pilot is over heating because of another problem, inspect/service the cooling system.
Had your Engine "hoserized" this head works perfectly with my setup its the same dome design I ran on my full mod Pilot that ran side by site with 4 of the CR500 modified ATV Racing Pilots two of them were the "race gas" CR500 engines, 41mm carb, pipe, clutch, rev limiter bla bla bla, are their better dome designed than this one sure are bring them on, this dome design is used because its been tested from stock to full modified on many Pilots, its safe, it works, its a proven, reliable design.
On a side note I also for a while ran a 47cc dome with my same hoserzed Engine gave a increase in throttle response and acceleration but since nobody else was keeping up with the 49cc dome I didnt bother running the 47cc dome, whats the point.
I did cut one dome for a special version of my hoserized cylinder that was only run for a really short time, this setup is in the vault here at the hoser compound awaiting for someone to produce what they think is a really fast CR500 Engine or another really fast 400 Pilot then I will pull it out and show them what real power feels like, this setup requires race gas even with 93 pump gas its running in slight deto all the time, you run it 1/2 hr pull the dome and the squish band looks like you sand blasted it
polish it up like a mirror reinstall, run 1/2 hr looks sand blasted again, leaves black marks on the pavement 15-18' long
In case others has not figured it out yet PilotDriver = that KTM265 mutt that I ban from this site a while back...... being the loser and dishonest jackass he is he came back like the rest of the Darksiders do with a different name, email address, IP address to continue being a first class mutt, seems he does not like the Darkside and wants to be part of the biggest and BEST Pilot/Odyssey website in the universe.
