It is currently Sun May 18, 2025 6:18 pm
 Post subject: Fl350 rear hub options
PostPosted: Fri Feb 15, 2013 11:46 am
Hi I was wondering if anyone knew of any rear hubs I could replace my stockers with? I did an A-arm conversion on the front and the pattern is now 4x144 and I'd like the rear to be 4x110 like trx450R or any sporty quad hub? Any options I'd have? Thanks
PostPosted: Fri Feb 15, 2013 1:46 pm
PostPosted: Sat Feb 16, 2013 12:39 pm
yeah I found some adapters I could use, but id rather run just a different hub if it were possible
PostPosted: Mon Mar 11, 2013 12:37 am
DaveM, how does the conversion work? I am interested. Any other pictures?
PostPosted: Mon Mar 11, 2013 8:52 am
They do the job. Just 3/8" plate machined to fit. The old stud holes in the hub are tapped. You need a good tap for this as the hubs are pretty tough material. Not shown in the pics but I put jam nuts on the backside to help keep it all together. Everything red loctited. They've been on there for 3 years no issues. I run factory Rhino take-offs I picked up cheap, had to make-em work.
PostPosted: Wed Mar 13, 2013 1:12 am
I don't know if this will help but 85 and 86 suzuki lt250r 4 lug hubs fit with a spacer for the seal. 87 to 89 five lugs hubs fit with a spacer as well.
