cylinder questions http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=12049 |
Page 1 of 1 |
Author: | brandonTKZ [ Wed Apr 24, 2013 12:00 pm ] |
Post subject: | cylinder questions |
I have a 80mm cylinder and a 78.5mm cylinder I figured Id keep the 78.5 but i cant seem to find any piston kits for it? should I just use the 80 and sell the 78.5? Thanks |
Author: | B S [ Wed Apr 24, 2013 9:15 pm ] |
Post subject: | Re: cylinder questions |
Honda quit making the stock pistons years ago All that's available are weisco pistons at 80,80.50,81,81.50,82mm available I would keep bouth if you can Or Use the 80 mm one first You might find an oem Honda piston for the 78.50 mm one I'm the future |
Author: | brandonTKZ [ Thu Apr 25, 2013 9:21 pm ] |
Alright thank you, Ill order an 80mm piston then |
Author: | consol [ Fri Apr 26, 2013 12:16 am ] |
brandonTKZ wrote: Alright thank you, Ill order an 80mm piston then ART pistons pop up on ebay from time to time, I'd keep the small bore as is in case you find one |
Author: | B S [ Fri Apr 26, 2013 12:41 am ] |
consol wrote: brandonTKZ wrote: Alright thank you, Ill order an 80mm piston then ART pistons pop up on ebay from time to time, I'd keep the small bore as is in case you find one generally ill buy them when i see them |
Author: | brandonTKZ [ Fri Apr 26, 2013 9:50 am ] |
The cylinder is for my brothers buggy since mine has the 583 and he doesn't know if he's going to keep the buggy so I think I'm just going to sell the 78.5 cylinder |
