PilotOdyssey.com
Fox air shocks on stock front a arms?
http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=16186
Page 1 of 1
Author:  nickRNR [ Mon Nov 09, 2015 3:25 pm ]
Post subject:  Fox air shocks on stock front a arms?
Fox980-02-014-A
Fox-2.0 Air Shock Non-CoilOver 4.5" Travel w/ 1.25" Shaft #980-02-014-A
I am wondering if anyone has tried to fit these shocks on the front of a FL400 with stock arms and stock brackets? Here is a link with collapsed and extended lengths for various shock sizes…
http://www.polyperformance.com/Fox-2-0-Air-Shock
I am not sure what the length specs are for the stock front FL400 shock.
I know the Yoda arm kit calls for the 5.5’’ travel shocks #980-02-015-A and using upper shock mounting brackets. Has anyone tried THESE shocks and brackets with stock lower arms?
I’m helping Westecbuilder with a project, changing to fox airs on all 4 corners and still using the stock front arms.
Thanks.
Author:  canadian oddy [ Mon Nov 09, 2015 5:32 pm ]
Post subject:  Re: Fox air shocks on stock front a arms?
Two hundred and thirty five dollars for one four inch stroke shock :shock:
I am not knocking the product just the price.
Boys were are in the wrong line of work -- all of us.
Author:  Randman [ Mon Nov 09, 2015 7:40 pm ]
If you think that's bad, go price what Works want's for their shocks. Please be sitting when you do the search... LOL!
Dark Angel just picked up a pair of these for the price of one.
I believe it was a screw up on the vendor's part, I think they meant to say a piece but the ad said for a pair.
I hope they don't screw him on the set!
Author:  hoser [ Mon Nov 09, 2015 9:25 pm ]
That was the first suspension mod I made on my Pilot, its been so long ago I forget the exact details, I changed my upper mounts to adjustable mounts because at the time I was not sure what I wanted to do and wanted adjustability, I fabricated all my own spacers, I used 1/2" bolts and drilled out the lower holes in the arms.
I love them I used them with my +2 arms too, using the stock arms I went from bottoming out the front suspension 500 times a trip to never bottoming. the improvement was so great the rear shocks felt like they needed something so I replaced them too.
Author:  nickRNR [ Tue Nov 10, 2015 12:52 am ]
Ok Hoser, which shock part # did you use with the stock arms?
Author:  hoser [ Thu Nov 12, 2015 12:46 pm ]
Think I used the 4.5" stroke, its been so long I cant remember for sure, if you check the over all length I think it will be self explanatory.
I think I have most the FOX Air shox info concentrated on these pages?
http://www.pilotodyssey.com/fox-home.htm
viewtopic.php?f=29&t=7080
Wish FOX made a bolt on kit for the stock arms I really like these shocks.
Author:  hoser [ Thu Nov 12, 2015 12:55 pm ]
Just followed your link I will measure the over all length tonight.
Author:  nickRNR [ Thu Nov 12, 2015 7:24 pm ]
That would be appreciated, thanks.
Author:  nickRNR [ Mon Nov 16, 2015 12:13 am ]
Any measurements?
Author:  nickRNR [ Tue Nov 24, 2015 1:42 pm ]
Still waiting for measurements. Anyone?
https://www.youtube.com/watch?v=f4zyjLyBp64
https://www.phpbb.com/
