Roof compartment http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=5038 |
Page 1 of 5 |
Author: | marioparra78 [ Thu Jan 08, 2009 7:56 pm ] | ||
Post subject: | Roof compartment | ||
Im been try to duplicate some roof compartments for a pilot. If i succeed i will be selling or trading them for stuff. If I succeed. this is the first big mold that i make. Im using polyurethane for the for the compartment and fiberglass with resin for the lid.
Author: | marioparra78 [ Thu Jan 08, 2009 8:01 pm ] | |||
Post subject: | ||||
as you can see my mold has defects that i still need to fix.
Author: | marioparra78 [ Thu Jan 08, 2009 8:05 pm ] | |||
I have material to work with just lacking the skill
Author: | marioparra78 [ Thu Jan 08, 2009 8:07 pm ] | ||
Post subject: | |||
My first try on the lid.
Author: | Hare [ Thu Jan 08, 2009 8:13 pm ] |
Post subject: | |
Looking good ! i have installed and repaired a whole bunch of that fiberglass pipe on condensate lines, we are one of the few that repair fiberglass. Are you a manufactuer? you said research, maybe a testing company? |
Author: | hoser [ Thu Jan 08, 2009 8:19 pm ] |
Post subject: | |
Before you get too far along... the lids made before could have had more storage space, going from memory they could have been slightly deeper (3/4" ?) longer and wider, you might consider making them larger? |
Author: | Ody_Stable [ Thu Jan 08, 2009 8:19 pm ] |
Post subject: | |
Looks good, much better start than I could've made. I was worried you'd given up when you didn't respond to my email. |
Author: | marioparra78 [ Thu Jan 08, 2009 8:21 pm ] |
Post subject: | |
I work at Ameron in the research department we make em and break em. for sewer, water and oil. from 1'' to 80'' what type of pipe do you repair. |
Author: | Ody_Stable [ Thu Jan 08, 2009 8:26 pm ] |
Post subject: | |
hoser wrote: Before you get too far along... the lids made before could have had more storage space, going from memory they could have been slightly deeper (3/4" ?) longer and wider, you might consider making them larger?
If I had pics with it installed from the underside that could be confirmed, but I don't. The plan was to trade a good FL250 bottom end for pilot roof or two, but the bottom end has a brand new Comet 94C clutch on it that I plan to use on the FL300R. It has no damn threads in the clutch to remove it, anyone ever seen a Comet clutch without the threads? I am going to have to build a puller just to remove it or obtain a very large tap....... |
Author: | marioparra78 [ Thu Jan 08, 2009 8:26 pm ] |
Post subject: | |
Sorry. i was in san luis with the inlaws came back tired now back on task I was thinking about the compartment size but first things first I got finish this before i modify |
Author: | Hare [ Thu Jan 08, 2009 8:35 pm ] |
Post subject: | |
marioparra78 wrote: I work at Ameron in the research department we make em and break em. for sewer, water and oil. from 1'' to 80''
what type of pipe do you repair. we do mostly underground work but will do mechanical stuff, water, sewer, storm, steam, condensate, gas and oil |
Author: | marioparra78 [ Thu Jan 08, 2009 8:35 pm ] |
Post subject: | |
don't worry about my bottom end until you some real progress out of my end of the deal. Im not doing any riding for a while. Im going this weekend to a plastics supply to get some ideas. |
Author: | marioparra78 [ Thu Jan 08, 2009 8:37 pm ] |
Post subject: | |
do you guys repair by adding a new liner to an old pipe. |
Author: | hoser [ Thu Jan 08, 2009 8:44 pm ] |
Post subject: | |
Ody_Stable wrote: hoser wrote: Before you get too far along... the lids made before could have had more storage space, going from memory they could have been slightly deeper (3/4" ?) longer and wider, you might consider making them larger? If I had pics with it installed from the underside that could be confirmed, but I don't. The plan was totrade a good FL250 bottom end for pilot roof or two, but the bottom end has a brand new Comet 94C clutch on it that I plan to use on the FL300R. It has no damn threads in the clutch to remove it, anyone ever seen a Comet clutch without the threads? I am going to have to build a puller just to remove it or obtain a very large tap....... What size tap? |
Author: | speedchaser [ Thu Jan 08, 2009 9:26 pm ] |
Post subject: | |
marioparra78 wrote: don't worry about my bottom end until you some real progress out of my end of the deal.
Im not doing any riding for a while. Im going this weekend to a plastics supply to get some ideas. this is a great place to start looking for info the tech are great too Ck out the Video Library http://www.freemansupply.com/index.htm looking good thou keep up the great work P.s. will that fit a fl350 thanks SpeesChaser |
Author: | Ody_Stable [ Thu Jan 08, 2009 10:31 pm ] |
Post subject: | |
hoser wrote: What size tap?
I have a 94C puller bolt in hand and it's 9/16 x 18 and it just drops into the hole, my guess is the previous owner drilled it out for some unknown reason or it came that way from the factory. I think a 3/4" tap would do it, but I will try the homemade puller first, a couple of 1/2" x 2" steel bars under the clutch and snug to the crank should do it. I have several more bottom ends but they're all in need of seals and/or bearings, only take an hour or so to rebuild, but I have yet to find my box of bearings and seals, went through 15 or 16 boxes this last weekend. |
Author: | hoser [ Thu Jan 08, 2009 10:51 pm ] |
Post subject: | |
Ody_Stable wrote: [quote="hoser What size tap? I have a 94C puller bolt in hand and it's 9/16 x 18 and it just drops into the hole, my guess is the previous owner drilled it out for some unknown reason or it came that way from the factory. I think a 3/4" tap would do it, but I will try the homemade puller first, a couple of 1/2" x 2" steel bars under the clutch and snug to the crank should do it. I have several more bottom ends but they're all in need of seals and/or bearings, only take an hour or so to rebuild, but I have yet to find my box of bearings and seals, went through 15 or 16 boxes this last weekend.[/quote] I have a 3/4" tap just used it last night to chase the puller threads on hare's 102C clutch before using his puller, his had dirt, grime, slight rust on the threads... I also have the 3/4" die nut, let me know if you need them, I probably have the 9/16 tap too. |
Author: | Hare [ Fri Jan 09, 2009 12:05 am ] |
Post subject: | |
marioparra78 wrote: do you guys repair by adding a new liner to an old pipe.
well do pull pipe on the small stuff but havent gotten into slip lining yet, you guys got any cool tricks? |
Author: | marioparra78 [ Fri Jan 09, 2009 6:58 pm ] |
Post subject: | |
we make fiberglass pipe with a sand core that gets pushed into an old pipe. all shapes all size. where you located? |
Author: | MassOdy [ Fri Jan 09, 2009 7:39 pm ] |
Post subject: | |
I like this thread! Thanks for the work. |
Author: | Hare [ Fri Jan 09, 2009 8:48 pm ] |
Post subject: | |
marioparra78 wrote: we make fiberglass pipe with a sand core that gets pushed into an old pipe. all shapes all size.
where you located? that sounds cool, I am in Mid Atlantic, Baltimore / DC area |
Author: | Vrroom [ Fri Jan 16, 2009 6:32 pm ] |
Post subject: | |
marioparra78, Are you the one that emailed me about making the lids? If you're plannng on getting a good quality finish, I recommend that you either contact the person that bought my molds, or have a fiberglass shop make them for you. Having a good mold is the key to producing good parts. I found that, unless you have a very high quality product, most P-O owners won't spend the money (or trade the parts) to put it on their machine. My monitary investment was considerable and my time investment was excessive. All things considered, I rate my product at slightly above average. I sold enough tops to break even, then stopped making them because it just took too much of my time. And besides that, the company that did the glass work went out of business. Good luck with your project. Vrroom |
Author: | mudbogger [ Fri Jan 16, 2009 6:41 pm ] |
Post subject: | |
Bill Okeffe has the molds?? |
Author: | marioparra78 [ Mon Jan 19, 2009 9:40 pm ] |
Post subject: | |
its been challenging to started. i got about three gallons of urethane for free. so money wise its not a big investment yet. just hours and hours of my time. i went to a plastics supply last weekend got a few ideas and i applied them. it workout. i been repairing the urethane mold and working on my casting techniques also trying different resins and pigments(grey black and silver)is all i got. ill put some new pictures up of my progress. I don't think my compartments will look as well as the OG but their always body filler, paint, and sandpaper. |
Author: | shoubadaba [ Tue Jan 20, 2009 1:43 am ] |
Post subject: | |
Trial and error that's how we achieve perfection. Keep going man you'll get it. |
Page 1 of 5 | All times are UTC - 5 hours [ DST ] |
