I guess i will just clean this pipe up when it gets here and decide if i want to keep it in my stash or sell it. My ody with the 350 has the DG pipe on it. Someone who has ran both could maybe chime in and tell what one they preferred? For now i will keep my eye out on a stock sled pipe.It will be a while before i get to the exhaust anyways. I need to finish wiring up the headlights tomorrow. I would like to have all the electrical done before a bunch of family is going to be over and more than likely checking out my work since it is in the center of the shop! i have most of the suspension parts painted.. i just need to assemble things now. I cant start installing them on the frame just yet because that still needs to be sent off and sandblasted and then either powder coated or painted. I got the banshee radiator on eBay a while back for $10 and free shipping but now that it is actually here i am not sure if i like the size of it. It looks to be a bit too small. Ive got a friend with a banshee so maybe i will sell it to him and make my money back. I was looking at an aluminum Honda civic radiator that people have said they ran and right now that looks to be about the best choice. Once i get my wiring all finished and confirmed working i will post up how i wired in the odyssey switches into the sled harness in case someone in the future does this same swap. will solve a little bit of trial and error and fuse blowing when you forget that the ground wire on the stock odyssey is green..... anywho that is where i am at right now.
Couple things that i have been wondering about are how do people usually wire in the water pump. I will be using an electric water pump since the manual one that was bolted to the side of the
Engine will no longer fit. The pump that was in the parts package with this odyssey was from a Mercedes. Its simple to wire it to power yes, but i was wondering if people usually wire the water pumps so that it starts to pump as soon as you turn on the key, or is it that it starts to pump as soon as the Engine fires? I would think that the best way to do this would be to do it so that if the Engine is running the pump is also and if the Engine is not running the pump is not running. that way if you forget to turn the key off you don't run your battery dead(granted you probably would hear the pump running). If this is in fact the best way to go, how would i go about wiring it. there is a wire that comes directly from the magneto(hope this is the correct word) on the Engine that used to be for the hand warmer circuit on the sled. Would that be a wire that i could tap into for the water pump or is it not going to be the correct/not enough amps/voltage.
Next question i had was about the seized up wheel controls. the brake levers, and throttle lever is froze up solid. Again guessing that this thing sat outside is the reason for this. I have tried PB blaster on all of the places where it could be seized with no luck. they move a bit but are still extremely stiff. Is there any trick to freeing these up? I really don't want to have to buy another one of these because the wheel itself is in good shape, just the machine was unfortunately left outside. It is bad enough i am going to more than likely need an entire new set of cables..brake, throttle, parking brake... thank god for Christmas money!
Thanks, Matt.
