It is currently Sun May 18, 2025 3:56 pm
PostPosted: Thu Sep 10, 2015 12:35 pm
Hi guys, new member here. I purchased a Honda Odyssey FL250 yesterday, actually this is the first one I ever seen in my country. The bike was put in storage a year ago and currently is not starting. I plan to remove the old fuel and clean the carburetor. The focus on the spark, which is very weak and intermittent. But that is for later, I already saw there are many interesting topics here on the forum.
Pics:
To do:
  • Engine not starting
  • Seat cover, fix or replace
  • Find original rear fenders (left on on Ebay, right not found yet)
  • Find original air filter cover and air filter
I considered to do a full restoration but figured it will be too difficult and/or expensive because all of the small missing bits. Anyway, I'm really looking forward to give it a spin.
PostPosted: Thu Sep 10, 2015 1:43 pm
Welcome and that is a good looking odyssey. Let some air out of those tires, you will get a better ride. No rear suspension is a pain - literally. Maier makes a fender replacement set. I bought a yellow set for my 1977 odyssey.
Many parts still out there for the FL250.
https://www.maier-mfg.com/catalog/honda ... ar-fenders
PostPosted: Thu Sep 10, 2015 5:00 pm
I had a weak then no spark issue with a ATC110 after it was stored for a long time first thing I did was swap the spark plug with a known good one then removed the spark plug cap cut off about 1/4" of the wire then screwed it back on, still no spark so I started to unplug all the plug of connections one at a time to ensure they were all clean and tight then testing for spark, found one connection that was dirty cleaned and then it had spark. The ATC harness has the same type connectors as the FL250.
