It is currently Sun May 18, 2025 3:55 pm
PostPosted: Wed Dec 03, 2008 10:34 pm
new member in west MI. just bought a 85 350 and 89 400. just trying to learn as much as possible about these toys. wanted one since 89 finally found a couple.
PostPosted: Wed Dec 03, 2008 10:40 pm
Welcome Rigger,
have a look around at all this info, I've not even scratched the surface & have managed to get alot of parts that I couldn't have found before.
"Hi, my name's Damon & I'm addicted to my ody." :-)
PostPosted: Wed Dec 03, 2008 10:50 pm
thanks, that's exactly what i am finding out, wow what a lot of info it all helps. i am pretty excited i ordered new plastic for the pilot today, the old isnt to bad but i want it to look really nice. i have been reading about the torq pipe-- does that help a lot?
PostPosted: Wed Dec 03, 2008 11:04 pm
Apparently they do, but, I'm still waiting on mine to be made & send by the manufacturer.
I too have a full set of plastics coming for my 350. Not lucky enough to own a pilot.
PostPosted: Wed Dec 03, 2008 11:10 pm
Welcome to the Forum I'm just north of G.R.
there is a lot of good reading and a lot of nice people here to help out if you have any questions
so pull up a chair and have a good look around
P.S. there is a lot of good info on Hoser's home page too http://pilotodyssey.com/
SpeedChaser
PostPosted: Wed Dec 03, 2008 11:45 pm
Hey Speed,
When are you going to make up some fender brackets??? I've seen you work & it's second to none, surely those little brackets would be a walk in the park for you?
PostPosted: Thu Dec 04, 2008 2:37 am
Welcome to the site
PostPosted: Thu Dec 04, 2008 6:35 am
Hi and welcome to the site, any pics of your new toys?
Christmas came early :-)
PostPosted: Thu Dec 04, 2008 11:57 pm
The combination of a Torque pipe and ported cylinder will not disappoint. Throttle response is night and day difference from stock....
WARNING; Once you start modifying stuff it will never end! :shock: A little Engine work leads to an aftermarket clutch followed by; front suspension work, steering work, a seat, harness, rear suspension work.... Then maybe a little better braking. Then your Pilot can handle more power so back to the Engine to squeeze out some more power and repeat!
Did I forget anything guys? :-)
PostPosted: Fri Dec 05, 2008 12:58 am
Sounds about right
