FL350R radiator redoo and refresh http://www.pilotodyssey.com/PO/viewtopic.php?f=61&t=10785 |
Page 2 of 2 |
Author: | Randman [ Mon Oct 22, 2012 12:53 am ] |
Post subject: | Re: FL350R radiator redoo and refresh |
You'll pay more for shipping than the part. They're less than 10 bucks a piece. There is no need to run the hose all the way up to the air box. Open Vent V/S Bellows: Open Vent, no bellows: You can run a vent system without the bellows however there are some issues in doing so. If you run too small of a vent hose, the oil will travel up the hose and out the un-vented end. Turbo Texas had oil that traveled up his vent hose probably a good 2 feet! What I have found with my testing is that the hose ID has to be large enough to allow the air to escape up the hose without pushing the oil along with it. I have seen people use a large filter in place just above the vent in the case. The large diameter filter will allow air to pass through the oil that is pushed into the filter. The end of the hose will still have to be protected from debris being drawn back into the tube and beware that some of your ballancer oil is stuck in your oil filter which isn't lubricating anything. Closed Vent, Bellows: The bellows system works extremely well by not allowing air to flow quickly up the vent tube and it is not effected by the size of the vent tube used. This keeps the oil in the ballancer where it belongs. As I mentioned before, I have experienced blow by by using a bellow that does not expand properly. Rand |
Author: | B S [ Mon Oct 22, 2012 7:48 am ] |
so the bellow is the best bet guess what the bellow for the outlander is discontinued |
Author: | Randman [ Mon Oct 22, 2012 11:21 am ] |
Shit! There is more than likely numerous atv differentials that use that bellow. I just happened to discover this one by looking at the neighbor's Can Am Outlander. Here is one that looks like it might do just fine from a golf cart differential. 10 bucks and free shipping. http://www.ebay.com/itm/E-Z-GO-VENT-BEL ... 3cca79d098 You'll just have to do some searching. Rand |
Author: | B S [ Mon Oct 22, 2012 11:42 pm ] |
Just ordered an bellow cost me $11 |
Author: | B S [ Sat Oct 27, 2012 9:12 pm ] |
What kind of silicone do you guys use on the exhaust header ? Hi temp red? |
Author: | B S [ Sun Nov 04, 2012 9:21 pm ] |
Well....I haven't done much to my odyssey lately just been so buzzy lately with work All I did was put the fitting on the air box so that's done it's just a long process lately I figured out what I'm going to do with the radiator Any one know any thing good to clean aluminum with? |
Author: | B S [ Thu Nov 29, 2012 3:35 am ] |
well i got quite a bit done with the radiator i feel like a dumb ass i cut a slice in my radiator with a cut off wheel so now i have to order a new one |
Author: | hoser [ Thu Nov 29, 2012 8:06 am ] |
Post a pic of the slice |
Author: | Fatcat [ Thu Nov 29, 2012 9:22 am ] |
Did you everfigure out where that airbox lid came from. I still havnt seen another one like it. |
Author: | B S [ Thu Nov 29, 2012 11:41 am ] |
Fatcat wrote: Did you everfigure out where that airbox lid came from. I still havnt seen another one like it. Nope |
Author: | B S [ Thu Nov 29, 2012 11:43 am ] |
hoser wrote: Post a pic of the slice Already tried to fill it It cut deep into 3 flutes It's with an 1/8 cut off wheel so I'm screwed |
Author: | Randman [ Thu Nov 29, 2012 12:17 pm ] |
It can be brazed to fix the cuts. Rand |
Author: | B S [ Thu Nov 29, 2012 12:25 pm ] |
Randman wrote: It can be brazed to fix the cuts. Rand Nope already tried |
Author: | Randman [ Thu Nov 29, 2012 1:04 pm ] |
Bummer Dude! That sounds like something I would do! Rand |
Author: | afastcar [ Thu Nov 29, 2012 1:47 pm ] |
Can you give us a close up pick of the cut? How many rows of tubes? Usually they have 2 rows, you can carefully dig the fins (aluminum) out around the cut tube with needle nose pliers and a pick, then cut all the way across the tube in between the slice, fold each end of the tube back over on itself and pinch each end off, it will just cancel that tube out, quick fix to get you by in a pinch. |
Author: | B S [ Thu Nov 29, 2012 1:56 pm ] |
afastcar wrote: Can you give us a close up pick of the cut? How many rows of tubes? Usually they have 2 rows, you can carefully dig the fins (aluminum) out around the cut tube with needle nose pliers and a pick, then cut all the way across the tube in between the slice, fold each end of the tube back over on itself and pinch each end off, it will just cancel that tube out, quick fix to get you by in a pinch. I'm am aware of that but I don't want to half ass it to where it could screw me in the future I would rather do it right the first time |
Author: | afastcar [ Thu Nov 29, 2012 2:04 pm ] |
Just good tricks if your out ridding and hit something so your not stuck or parked on the trailer the rest of the weekend. http://www.stockcarracing.com/techartic ... ewall.html Search words, radiator, leak, core, repair, quick fix, hole, cut, antifreeze, how not to use a cut off wheel |
Author: | B S [ Sat Dec 01, 2012 2:22 am ] |
afastcar wrote: Just good tricks if your out ridding and hit something so your not stuck or parked on the trailer the rest of the weekend. http://www.stockcarracing.com/techartic ... ewall.html" .".. Search words, radiator, leak, core, repair, quick fix, hole, cut, antifreeze, how not to use a cut off wheel I JUST don't WANT TO HALF ASS IT BUT...that's GREAT TO KNOW FOR THE FUTURE |
Author: | B S [ Sat Dec 22, 2012 12:18 am ] |
got the radiator done but i diddnt snap any picts i did the nuke em gas light modd |
Author: | turbo [ Sat Dec 22, 2012 9:24 am ] |
have you looked at putting some insulation over that figure 8 wire where it could rub on the metal? |
Author: | B S [ Sat Dec 22, 2012 11:19 am ] |
turbo wrote: have you looked at putting some insulation over that figure 8 wire where it could rub on the metal? im going to just haven't yet |
