It is currently Thu May 15, 2025 9:12 pm
PostPosted: Sat Oct 19, 2013 12:30 pm
As of this writing still available from Honda
91203-950-003 OIL SEAL (30X55X10)
http://www.partzilla.com/parts/detail/honda/HP-91203-950-003.html
NOTE
To replace both crank seals you have to split the cases and remove the crank bearings their is no way to remove the crank bearings without stressing the balls so BOTH crank bearings need replaced when replacing the crankshaft seals.
If your crank seals are leaking you will need two new crank bearings and both seals and a full Engine gasket kit.
Mutt on ebay selling both seals for $34.99 you can buy both for $18.28
