It is currently Wed May 14, 2025 9:23 pm
PostPosted: Thu Apr 16, 2009 10:54 pm
http://www.utah.com/stateparks/sand_hollow.htm
Sand Hollow State Park in U...pdf [282.15 KiB]
Downloaded 183 times
PostPosted: Fri Apr 17, 2009 11:30 am
I opened up the map and noticed the Valley of Fire park near Logandale. Several years ago I got my first taste of SAND here and the rest is "History"
http://www.offroadadventureguide.com/Tr ... s_Map.html
I was laid over near there and rented an ATV from the above link. Me and a guide went on a ride for several hours and it included desert trails and Mining roads, and the prettiestt sand I have ever seen... Almost a pink color The dunes had some trails ie. little sahara's in Ok and some major hill climbs too!!! I was on a Bombadier outlander 4x4 400cc with stock tires and still had a blast...
You would enjoy this spot, and do not require a Guide if you go...
PostPosted: Fri Apr 17, 2009 5:24 pm
Some where in that area of North Vegas their is sand dunes too.
PostPosted: Fri Apr 17, 2009 7:55 pm
Yep been there too... I posted here somewhere http://pilotodyssey.com/PO/viewtopic.ph ... egas+dunes
Of the two I would like to go back to the logandale area just a bit cleaner and further away from it all.. The dunes were better there also!!!
