It is currently Thu May 15, 2025 6:57 am
PostPosted: Thu Jul 03, 2014 1:58 pm
Pilot Radiator Relocate Brackets no weld solution Fast, Simple, another money saving idea by hoser..! No I didn't invent the relocate mod I made it better..
I am not sure why people want to weld when they are relocating their Pilot radiators I also don't understand why they want to give ATV Racing 160 bux for a weld on kit when you can make a fast and simple bolt on kit for about 5 bux and 1/2 hr of your time.
Here is the one I made from pieces of 3/4" x 1/8" flat hot rolled steel you can get at about any hardware store for a few bux, you just cut to length then drill a hole at each end, you use all the Honda bolts and mounting locations, you do have to cut the factory cross bar the radiator is mounted on but people are removing that bar anyways.
Some day I will remove the brackets and drill more holes to remove some weight and paint them so they quit rusting :shock:
More pics here viewtopic.php?t=813
PostPosted: Thu Jul 03, 2014 6:13 pm
Hoser, does the cross bar that gets cut out get replaced?
PostPosted: Thu Jul 03, 2014 8:26 pm
Yes I made a bolt in replacement you can see it some in these pics viewtopic.php?f=72&t=837 and here
viewtopic.php?f=72&t=813
PostPosted: Thu Jul 03, 2014 8:49 pm
That looks pretty slick!
Good job!
