It is currently Thu May 15, 2025 4:40 am
PostPosted: Mon Dec 12, 2016 8:38 am
Spent the weekend installing a totally dif sensor setup.Not much luck with the others.
See how this one goes,all thru own relay,and secondary A/C wire(which I've wired up with an LED/toggle switch to overide the sensor.
The manual switch I chose has the LED at the toggle switch end.Nice and bright.RED of course...the redder the bedder?
You can dial in the required fan temp startup,also has the ambient temp display.
And Yeap,ELVIRA'S still rockin' it Ak!!! :-)
PostPosted: Mon Dec 12, 2016 10:47 pm
PostPosted: Wed Dec 14, 2016 8:18 am
Fancy
Not bad
PostPosted: Wed Dec 14, 2016 12:51 pm
You got more gauges on that machine than a F1 car.
Your gona crash it lookin at the cool stuff.
On my formula car I had, everything was on relays. If the water temp went over the set it killed the ignition, same with oil pressure. No time to look at gauges.
The girl on the steering wheel -- why are you lookin at her headlights ?? Aren't you suppose to be drivin ??
