It is currently Tue May 07, 2024 4:05 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Sun Oct 21, 2012 1:54 am
I'm wondering what's needed to put an dual pre filter set up on an fl350 air box with the k&n pre filters
I'm wanting to get ride of my k&n set up
And go with an stock box with an pre filter set up
PostPosted: Sun Oct 21, 2012 9:56 am
This is the set up I did for my daughters 350 Ody.
I used 2" muffler tubing to build the prefilter. You can buy an 18" piece at Autozone for about 5 bucks. It will be expanded on both ends to so it would slip over another 2" piece. I used the expanded ends for the filter sides of the prefilter and the other end to slide the 2" shop vac hose over to connect to the air box. the 2" shop vac hose came from Home depot and was 20.00 for the kit. The K&n filters are part # RU 0620 and I bought the pair on feebay for 64.00 shipped.
PostPosted: Sun Oct 21, 2012 2:47 pm
Do u got more detaled photos on the box ?
I'm guessing 2 in" or 1 3/4 in" pvc coupler
How did u attach it in side the box ?
this the filter u bought ?
http://www.ebay.com/itm/K-N-RU-0620-OD- ... 3b&vxp=mtr" ."..
and i'm guessing the cover that fit them?
http://www.ebay.com/itm/K-N-RU-0520PK-B ... 257643d7e9
PostPosted: Sun Oct 21, 2012 9:02 pm
Here is tho only other i had from doing the box..
yes those are the filters I used, I don't remember the part # on the covers, but I would not buy them again. I would just use some old pantyhose as Hoser suggested.
PostPosted: Sun Oct 21, 2012 9:41 pm
I did a basic job on one of mine like this. I have been running it for close to 10 years and really like it. I got both filters n covers from ebay real cheap. Basic plumbing PVC thru holes. I also sealed the original hole. I run a good Uni in the box. This cheap easy mod will really wake up an Engine with so much better air flow so be warned, REJET!
Gary
PostPosted: Sun Oct 21, 2012 9:55 pm
Gary
I like the dual with the hoses up to the top look
But urs looks good too
And probably way cheaper
PostPosted: Sun Oct 21, 2012 10:03 pm
The big plus on running the hoses up top is that it gets the intake out of the debris thrown up around the Engine compartment.
PostPosted: Sun Oct 21, 2012 10:27 pm
45 min to 1 hr use after clean and reoil
File comment: K&n shit
File comment: Mount
File comment: The reason why k&n sucks ballz
PostPosted: Mon Oct 22, 2012 9:55 pm
Just bought an air box from ridindirty ,the k&n filters ,vac hose , and the muffler pipe
Who makes the best foam filter for the air box?
Twin air ? Uni?
PostPosted: Tue Oct 23, 2012 12:53 am
Unless I'm blind in one eye and can't see out of the other, it doesn't look line twin air makes a filter for an FL350. I have been know to be wrong in the past but only once and she has never let me forget it! LOL :shock:
UNI is tried and proven to work excellent. I actually cleaned one this evening!
PostPosted: Tue Oct 23, 2012 1:39 am
Ok that's what I thought
What did u guys glue the PVC to the box with ? Plastic weld?
I almost have all the stuff except fot the filters
I have an box here that I can start on I just didn't want to cut into this one till I had another one for my other odyssey that I want to keep stock other than the dg pipe
PostPosted: Tue Oct 23, 2012 2:30 am
The fitting fixed to the air box is held on by a nut on the back side. The elbow is then glued to the fitting.
PostPosted: Tue Oct 23, 2012 3:10 am
I just used silicone to hold the elbow in mine. (felt like the silicone homo) Works fine. I don't like the way it looks though. Will be starting over and doing a whole new airbox setup. My plan for the replacement is a Uni in the stock bottom, remove the deflector, and add another hole and a Uni filter to the top of the lid. I've got this sitting on the bench in the garage. I think it will look nice and clean. This will allow me to run the stock snorkel box without having to modify it. I like what Nukem did to his. Its very similar but with only one Uni pre filter.
PostPosted: Tue Oct 23, 2012 9:03 am
The fitting I used has a nut on the inside of the air box to secure it. I just used a little bit a silicone to make sure it was air tight around the fitting.
PostPosted: Tue Oct 23, 2012 2:08 pm
I can post more info n pics if you want to see other options.
This is what I love about this board, you can see what others have done making mods then tweek em to what you have or need. Lots of great ideas done here. I need to put all the goofy mods I have done to my 350s over the last 15 years n put em in my "Nuke Em" section, then you guys can can improve on them or have suggestions. I made tilt seats, air box mods, brake lights, nerfs, bumpers, lighting, limiting straps, fuel gage, skid plates, clutching, intake mods,etc etc etc.
Gary
PostPosted: Tue Oct 23, 2012 2:25 pm
Gary
Go ahead
The more the marrier
I would love to see the fuel tank gage
U ever make ur own nerf bars ?
PostPosted: Tue Oct 23, 2012 5:14 pm
I will when I get a chance later.
I have 3 different styles of nerfs. Elitespecialkid (Mark) has an uncle that is a welder by trade and is going to make several sets for us and is using one set as a model. I have a tube bender n welder and probably could but he does this kind of stuff for a living. we will post pics when I get em back.
As far as my gage setup, its more of a low level sensor that turns on with about 1/4 tank left. I like it.
PostPosted: Fri Oct 26, 2012 4:09 pm
I found the adapter I was looking for
The inside was too restrictive and the nut wouldn't bottem out so off to the lathe
[/IMG%20Image
No more lip
Done
PostPosted: Sat Oct 27, 2012 8:20 pm
Should I cut out the baffle or not
Is the lid on the right a pilot lid ?
PostPosted: Sat Oct 27, 2012 9:01 pm
I did but in hind sight wouldn't do it again. That shield keeps water from hitting the filter so that is a good thing.
Those are both FL350 lids, although that is the first one I have seen with that warning on it.
PostPosted: Sat Oct 27, 2012 9:09 pm
I thought the fl350 olny came with breathers in the lid ?
What one should I run?
I'm thinking the one with out holes in it just in case I might go threw mud or light water at times
PostPosted: Sat Oct 27, 2012 9:11 pm
someone added those breathers to the first lid, no 350 ody came with those from the factory. I would use the second lid.
PostPosted: Sat Oct 27, 2012 9:58 pm
I always thought they came with them from the factory
PostPosted: Sat Oct 27, 2012 11:00 pm
No sir, i forget the name of the company that sold them, but they are not factory.
PostPosted: Sat Oct 27, 2012 11:13 pm
It's uni if I Rember
Registered users: Bing [Bot], chorizofingers, Google [Bot], Lanix
