It is currently Sun Nov 10, 2024 3:47 pm
 Post subject: Re: Honda FL250 project
PostPosted: Sun Dec 30, 2012 6:03 pm
I understand your jets are clear, but are the air passages feeding the idle circuit open?
Crank case leaks cause a lean condition in a 2 stroke, not a rich condition which is what your plug is showing.
When you are having to hold the throttle slide open, this is an indication that the air fuel mix is needing more air which it is not getting from the idle circuit.
When there is a seal leak, the plugs will be a light tan in color. This condition will burn up an Engine quickly.
You may have a weak ignition problem.
PostPosted: Sun Dec 30, 2012 8:41 pm
Ok now that makes more sense.
How do I check the ignition system?
Could my timing be off? That's what caused the lean condition in my 90 but that's a 4 stroke.
Are the air passages shown in the Manuel?
PostPosted: Sun Dec 30, 2012 9:33 pm
No, the passages in the carb are not defined. You will see in the bottom of the intake opening of the carb a small air passage, make sure it is clear. If memory serves me right, there is also a small passage just either in front of the slide or under the slide. Its been a while since I've played with a 250 carb so I might be wrong. The important thing with these carbs is to make sure all of the passages are clear, if not it will not idle properly.
As far as timing goes, yes it could be off. I believe by the looks of your Ody it has a solid state ignition and not points like the early 250s but like I don't remember what year they went from points to solid state ignition.
Download and read the manual about how to test the ignition and set the timing.
PostPosted: Sun Dec 30, 2012 9:46 pm
Ok I'll check later and post a pic.
And yes I have a CDI (Capacitor Discharge Ignition) set up.
PostPosted: Mon Dec 31, 2012 4:01 pm
Ok im just going to give up for a while. Tried to pull the fly wheel and screwed up the treads. so now i have another problem.
Im going to wait on my order to come in and go from there. This sucks
PostPosted: Mon Dec 31, 2012 4:47 pm
Welcome to the world of screwing with Vintage 2 Strokes!
Don't give up, you'll get it!
PostPosted: Fri Jan 11, 2013 1:11 am
ok passed all that just working on the crank and inspecting all the bearings.
They all look good and feel tight.
bought the clymer manuel and its pretty good.
gottA get the seals and put back together!
File comment: Got the clutch off with the puller kinda on good.
File comment: look at the dent from my vw!
PostPosted: Mon Jan 21, 2013 4:57 pm
I bought a 20 ton shop press from harbor freight. Almost done putting the Engine back together.
File comment: Got the motor (( Internal Combustion Engine ? )) back together
File comment: Fuel filter on and everything is ready for the Engine to be put back on.
PostPosted: Tue Jan 22, 2013 10:29 am
Just make sure to use the freezer and oven as needed to make the job simple for the bearings, cases, and crank. Don't go cracking cases with a shop press! Been there, done that and it sucks.
PostPosted: Tue Jan 22, 2013 2:03 pm
Can I just press in the seal?
How hard is it to press the bearing in and do you have any tips ?
PostPosted: Tue Jan 22, 2013 3:22 pm
You freeze the bearing and it will contract and heat the case and it will expand. With the difference in size between the two while heated and frozen, the bearing will fall right in, no pressing required.
PostPosted: Tue Jan 22, 2013 3:25 pm
Put the seal in after the bearings - you do not want to heat the seals. seals should be driven in with a seal driver.
http://www.harborfreight.com/18-piece-s ... 35555.html
PostPosted: Fri Feb 08, 2013 12:30 am
Update , I got the Engine back in. It runs. But it very very hard to start. Had to take the air filter off for it to crank. But when it runs I put it in and she ran fine. I ran her for a while and could not restart her, after I let it cool back to room temp. The plug was carbon fouled pretty good.
It won't crank with a new plug and haven tried to take that air filter off.
So what should I do to try to correct this problem ???!!!!!
PostPosted: Fri Feb 08, 2013 3:01 pm
Did you do a leakdown test and a compresison check after you had the Engine all together?
Stock jetting? Stock airbox w/ lid? 32:1 fuel/oil mix?
PostPosted: Fri Feb 08, 2013 3:04 pm
No leak down test. don't have the stuff for it. It running too rich, not too lean so i don't see why that would be a problem. It does run its just hard to start. and carbon fouls the plug.
PostPosted: Fri Feb 08, 2013 3:07 pm
Yes stock jetting but has had a rebuild kit. stock airbox with lid a little bent up and running 30:1 yamalube mix
PostPosted: Fri Feb 08, 2013 4:29 pm
couple of things: did you check the backslap on your reduction box chain? sorry to be a PITA but it looks like it could be close to touching the case.
all of that carbon on top of the piston should come of before you run it, and it is caused by incorrect fuel/air ratio (i believe) is your air filter clean and oiled?
depending on how bad the threads on the shaft are, you may be able to get them ok with a thread file, also your woodruf key might be buggered making it real hard to get the flywheel off
PostPosted: Fri Feb 08, 2013 4:42 pm
That's all dune. Everything is good.
I just can't get her to crank right.
PostPosted: Fri Feb 08, 2013 9:23 pm
spark plug gap ok
PostPosted: Fri Feb 08, 2013 9:26 pm
nice machine btw
PostPosted: Fri Feb 08, 2013 9:33 pm
if your losing spark have a look at the wires at the back of the CDI (Capacitor Discharge Ignition) harness plug, the CDI (Capacitor Discharge Ignition) is sealed so probably not getting gas in it
PostPosted: Sat Feb 09, 2013 1:13 am
Yea man everything like that works she is just really hard to start? I have no idea why.
Registered users: Bing [Bot], eseymour72, Google [Bot], hoser, Lanix, MSN [Bot], MSNbot Media, W3C [Validator]
