It is currently Sat Apr 27, 2024 6:02 am
PostPosted: Sun Mar 24, 2013 9:37 am
Hello all-
I was referred here from "tedpilot", a friend over in a private forum at atvconnection.
Maybe you guys can help me out on a few parts?
So- I recently acquired an fl250 that I'd like to restore. I traded an iphone 4 and a couple hundred $$ for it.
One of the previous owners, I guess, had raced it on a track, and had built a modified roll cage on the 250 platform. At the moment,
you pretty much have to enter it from the top and drop down unless
you're a contortionist and can twist yourself in from the side.
He put the stock 250 Engine back on it when I bought it.
It has quite a bit of play in the splines where the wheel hubs meet the axle. Not sure if it's the axle or hubs that are worn.
I just ordered a stainless 5 gallon top tank for it. but I can't find a decent seat. Trying to find a high back buggy seat- but having no luck.
I can find'em for about $150-$250, but they want $120 to ship it! which is total BS imo! I can ship a flipping couch for $120!!!
The throttle cable is a bit stiff, and the steering wheel cover switches are in bad shape. The Engine has a new top end on it and does run, but I'm
considering selling the motor (( Internal Combustion Engine ? )) and replacing it with a 400 - 500cc sled Engine. The brake & clutch work great. There's quite a bit of play in the gear box- not sure what is normal-
I'll have to read up on it. Tires & rims are basically new. I'll be disassembling, cutting & welding over the next few weeks. Would love to find a high-back seat and non-worn hubs for it...
I'm in douglas, ma 01516 (about 90 minutes south of manchester NH or 25 minutes north of providence, ri)
PostPosted: Sun Mar 24, 2013 10:22 am
Welcome!
I saw this listed/posted on C.L.
Congrats on your acquisition...
I am also from Mass and have a friend in Dudley... We used to practice down at Uxbridge MX....
There are alot of 250 Odyssey units in Mass... There is one listed now on C.L. as an 88 Odyssey but is more in the 82 range
regards
PostPosted: Sun Mar 24, 2013 10:27 am
also
http://southcoast.craigslist.org/rvs/3691525485.html
wording from the above C.L. ad.
polaris snowmobile, honda odyssey parts shoot me an email (new bedford)
I have parts from at 1995-7 polaris xlt 600 and plenty vintage odyssey parts, also odds and ends motors.
Email for pics
PostPosted: Sun Mar 24, 2013 10:57 am
thanks, go oddy! :)
I'm on the fence on buying this fl350:
http://worcester.craigslist.org/rvd/3630127782.html
I offered him $1600 for it- and he accepted- needs suspension parts like b-joints and tie rods, a battery & starter solenoid.
the reason I'm on the fence is because I basically spent a couple hundred on aquiring this oddy, $1400 would go a long way into restoring this one. I found a couple fuel injected 500cc sleds on cl for $500and other than a seat and a few odds & ends, and a little hard work, I could have this thing looking & riding amazing. Plus, I really like the custom roll bar- I think it looks nice and it'll offer improved protection for when I roll it (and I will eventualy roll it :o )
however, I won't have the IRS that the fl350 has, which imo- is a big plus.
I relisted mine back on cl for the same pricee the other guy had it listed at- I figure I'll give it until my new gas tank arrives- if it sells, I'll go grab that 350 oddy, if it doesnt sell by the time the new tank arrives, I'll pull the ad and finish this one.
PostPosted: Mon Mar 25, 2013 12:53 am
any closer pics or info on that air box/canister?
PostPosted: Mon Mar 25, 2013 6:20 am
how's this pic?
PostPosted: Mon Mar 25, 2013 6:56 am
That's a Donaldson disposable air filter housing/cleaner canister.
They're cheap...http://www.everythingtruckparts.com/donaldson-c055003-duralite-air-cleaner
Really good dirt stopper, leaps and bounds over k&n.
PostPosted: Mon Mar 25, 2013 7:41 am
looks like it has a nice filter element in the can- the whole can & filter is one unit and is clamped onto the tube.
PostPosted: Mon Mar 25, 2013 8:48 am
What annoys me is that Donaldson reports NO PERFORMANCE information except for flow restriction on their website. What a joke. They know better than that! >=/
They've got an ECC and ECD version of these housing/filter units. The ECC air inlet is just outside the outlet, and the ECD flows from one end to the other.
http://www.donaldson.com/en/catalogs/Engine/033621.pdf
PostPosted: Mon Mar 25, 2013 9:11 am
I had the same problem finding a seat, I fabricated one out of Aluminum and put a walmart seat cover filled with foam over it, looks great, check out the picture!!!
PostPosted: Mon Mar 25, 2013 9:30 am
wow! that does look good!
I accept your offer- do you take pay-pal :D :p
PostPosted: Mon Mar 25, 2013 12:50 pm
guys! I did it! after searching for 2 days for a domestic supplier who sells nice seats and doesn't charge hundreds to ship it...
check'em out-
http://hunsakerusa.com/
this is the seat I just bought. $110 + $35 shipping :)
they have the same on in black that isn't a bolt-thru for only $80 + $35 to ship!
doesn't get better than that!!!
http://hunsakerusa.com/c-370515-poly-ra ... -thru.html
PostPosted: Mon Mar 25, 2013 2:25 pm
Did you check Summit Racing??
You can get a poly high-back Summit Racing seat for $39.95 + shipping. It's $63 to my door here in OH, but they also have a warehouse in northern OH. So may be more for MA...actually...I tried 02108 (eastern Boston) and its the same $19.45 shipping AND you don't have to pay tax like me - an Ohioan -- so its only $59.40 shipped.
http://www.summitracing.com/parts/sum-g2100
PostPosted: Mon Mar 25, 2013 3:10 pm
where the hell were you 2 hours ago!!!!!!!! grrrrrrrrrr
well- at least the one I bought is a bolt-thru which is stronger than these seats that have a bolt thread into a mounted stand-off in the seat.
not that it's all that hard to drill a seat.
PostPosted: Wed Mar 27, 2013 2:54 pm
How did this seat work out for you? What seat cover did you go with? Thank you for the input!
PostPosted: Wed Mar 27, 2013 3:29 pm
still waiting for it- should be here today or tomorrow ;)
PostPosted: Wed Mar 27, 2013 3:45 pm
Great! Keep me updated. Strongly considering going this route seeing that I was just quoted $300 to recover the stock seat...
