It is currently Thu May 15, 2025 6:47 am
 Post subject: Fl350 starter problem
PostPosted: Fri Jul 12, 2013 1:18 pm
My starter only works when you tap the start button until it starts, if I hold it down it sounds like its slipping. What do you think would cause this?
PostPosted: Fri Jul 12, 2013 1:29 pm
Sounds like you are not getting full contact in the start button. I woukd dissassemble and clean the switch and try starting it again. If that doesnt work might be time to rebuild your starter.
PostPosted: Fri Jul 12, 2013 1:33 pm
If you need to rebuild viewtopic.php?f=26&t=5939
PostPosted: Sat Jul 13, 2013 1:47 am
Ace wrote:
I know when my battery was low it would engage crank the Engine then disengage but still spin (the starter). Is your battery low?
mine did that also
