Reconditioning the cage nets. I came up with this idea because you cant buy replacements anymore.
Instructions
1. I removed the nets from the metal frame.
2. I had the metal frame powder coated black.
3. I washed the nets using laundry detergent and Biz in the sink in warm to hot water.
4. I rinsed them thoroughly.
5. I filled the sink halfway up and added 1/2 cup of white vinegar to remove any residue.
6. I redyed the net using iDye Poly Black Dye with color intensifier. (RIT Dye will not work)
7. I boiled the net for 2 hrs instead of the 1 1/2 recommended because the black is harder to dye.
8. I added water to the pan as the level dropped and stirred often.
9. Warning! The dye rises up in the steam and can coat the area surrounding the pan as well as the fan screen. It also has a very unpleasant smell. I would recommend that this be done outside on a single burner camping stove in an old pan that you will not use again.
10. The extra dye residue is very hard to wash out. It took at least 12 times for me washing it out with laundry detergent before the water was clear.
11. After all this the net did not shrink but the knots loosened up so I took my time to pull them tight evenly before I slid them back onto the frame.
12. The knots are not as tight as they were originally so the net seems a little tighter on the frame. If you wax the frame it helps it slide on easier.
13. I bolted it back onto the pilot.
This is not an easy task but it really looks nice if you are trying to restore a Pilot.
