It is currently Sun Apr 28, 2024 4:54 pm
PostPosted: Fri Nov 08, 2013 8:14 am
picked up a FL 250 cylinder off eBay
and decided to make a water jacket
PostPosted: Fri Nov 08, 2013 6:08 pm
PICTURES PICTURES.
Planning on making my fl350 cyl liquid cooled next week.
Will post pics.
PostPosted: Fri Nov 08, 2013 6:10 pm
PICTURES PICTURES.
Will post pics.
Tried to post them last night but diddnt work
Will post them today some time
I have a failed fl350 liquid cooled cylinder lol
I'll post a pic
PostPosted: Fri Nov 08, 2013 10:37 pm
Picts
PostPosted: Fri Nov 08, 2013 10:39 pm
All the fins
Air hammer and sawzaw took care of the fins :-)
File comment: Trash
PostPosted: Sat Nov 09, 2013 4:16 am
got some work done tonight
I don't have that much peace is a flat aluminum here so it's halfway done
PostPosted: Thu Nov 21, 2013 6:45 am
Done
Has one leak I got to fix
PostPosted: Thu Nov 21, 2013 10:53 am
You are one busy mo-fo! lol I'm jealous of your free time and ability to get some buggy work done.
TIG?
PostPosted: Thu Nov 21, 2013 3:59 pm
TIG?
yes its tig
im working the night secudgle here and don't go to bet till 4am or so :shock:
wont be getting any thing done tonight the new xbox comes out tonight :-)
plus i got to move sat and sun so i wont have any time this weekend
PostPosted: Fri Sep 19, 2014 1:14 am
i might sell this
message me if your interested in it?
PostPosted: Fri Sep 26, 2014 10:03 pm
Would'nt it be possible,more practical,stronger,quicker,EASIER,to just alu wrap around all the existing fins?
More heat transfer metal to coolant,plus jug strength,integrity.
I would try to drill the coolant transfer holes between all the inner fins on an angle to facilitate the flow between them.
One large long drill bit,drilled from the top and on an angle thru all the fins same time,strategically placed to facilitate the flow from the bot to the top and out.
Then wrap and weld the alu cover jacket.
A pump then would be plumbed into the bottom,with the outlet at the top.
IF all the holes go with the flow,then there would be like a swirling action around the jug,washing the heat away and up,exiting out the top and into the radiator.
PostPosted: Fri Sep 26, 2014 10:58 pm
I thought of that too when I was making my liquid cooled fl350 cylinders and heads but decided to do it the same way as BS because if you don't get proper flow on any part of the head or cylinder you will create a pocket for the water to just sit there and boil.That was my thinking at the time anyway.
PostPosted: Fri Sep 26, 2014 11:13 pm
Yes that's why I said strategically placed holes to facilitate flow.
If the transfer holes were drilled just straight up/down,then the coolant would'nt be effective,it would just flow straight up and out, not CHANGE ALL the coolant.
But if the holes were drilled on an angle,several full length up/down angled/staggered towards the top outlet,then I can't see how it would'nt work.
One trial jug could easily be knocked up,then test with a heat gun all the way around.
