It is currently Sun May 18, 2025 2:50 am
PostPosted: Wed Jan 15, 2014 12:16 pm
Hello, I need a coolant overflow tank for my Pilot. Do you know where I can find one or at least something that will work in its place? Thank you.
PostPosted: Wed Jan 15, 2014 12:59 pm
That's a hard one to find new. What is wrong with yours? You may want to check with pilotpete1 - you can send him a PM on this site. If your is leaking at the seam it may be repairable.
PostPosted: Wed Jan 15, 2014 1:54 pm
Just picked up this Pilot last weekend- needs some TLC. Tank is broken pretty badly, has been taped together!? Thanks for the info- I'll try to contact him.
PostPosted: Wed Jan 15, 2014 2:52 pm
Not trying to hijack the thread but we have discussed these over flow bottles before, we need someone with access to a 3D printer to try and duplicate one, another part we need to investigate to see if it can be duplicated is the Pilot fan blade I have seen many of these that the sun has killed them, I guess its possible that Honda used the same fan blade on another product but it carries a Pilot only part number 19020-HE0-003 FAN, COOLING
Anyways if they can successfully be 3D printed then we can setup with a vendor to have some made?
Registered users: c5racer, Google [Bot], Lanix, liduno
