It is currently Wed May 14, 2025 7:27 am
 Post subject: CV types
PostPosted: Sun Jan 26, 2014 3:08 am
Could someone explain the different CV types and their application for me? I think I have it understood, but I'd rather be sure.
 Post subject: Re: CV types
PostPosted: Sun Jan 26, 2014 9:19 am
Start here: http://www.blindchickenracing.com/How_to/CVJoints_Axles/cv_joints_101.htm
PostPosted: Sun Jan 26, 2014 1:32 pm
What aftermarket a arms if any, are a direct bolt on for the pilot with +2 +1?
PostPosted: Sun Jan 26, 2014 3:00 pm
atv racing and Dave-co here on the board
PostPosted: Sun Jan 26, 2014 4:08 pm
Who is a good source for type 4 cv's. Also are they all the same or do they have heavy duty versions?
PostPosted: Sun Jan 26, 2014 6:20 pm
Someone is bound to ask, so I'll be the first...what are you trying to do with them?
Is this for a pilot application?
PostPosted: Sun Jan 26, 2014 6:47 pm
It's not for a pilot. I have an old buggy that has type
4 cv's. I'm finding it difficult to locate replacements. Some say go to a
Type 2. Some web sites say it has less articulation than a type 4 others show
Off road ones where they claim up to 25 degrees. Don't know much about them
So right now I have more info than my brain can process. I would like to use 930
Cv's but I don't want to buy new axles.
PostPosted: Sun Jan 26, 2014 8:21 pm
How much angle do you need?
I think the type II CV's can be modified for a few more degrees angle Dave-Co or some of the VW guys can confirm this.
Why not just get some more type 4's?
You go talk to the guys at the Old Volks Home I think they just down the street from you?
PostPosted: Sun Jan 26, 2014 8:30 pm
PostPosted: Sun Jan 26, 2014 8:33 pm
Actually...I was asking about cv's For a pilot application. I want to run a 670 rot ax or so, and convert to 930 CV.
PostPosted: Sun Jan 26, 2014 8:34 pm
Not sure if Yoda is making them any more but here is some links to some reading about his arms
https://www.google.com/search?q=style+g ... S:official
PostPosted: Sun Jan 26, 2014 11:04 pm
You'll need a flanged stub shaft with the pilot 25 spline male end
I don't know of one off hand but maybe someone here has a source
PostPosted: Wed Feb 05, 2014 3:55 pm
OK...a better question yet. What trailing arms would be the best matchup to start with ordered. I don't have all the equipment at hand to make my own. I can do some fab work, but I'm converting to a 930cv setup due to part options/availability with a 5:1 gearbox. My 670 ho has all the power I need....lol. Also to widen the rear end some and to have a better suspension. The problem I've seen, is their all a arm form, or too long, etc. I just need a set with the correct length, micro stub axle supported, and angled enough to widen it about 6-8". I'm waiting on my Honda 450r a arms to get here so I could get exact measurement, but I'd like the rear to be the same width. Any suggestions?
PostPosted: Thu Feb 06, 2014 8:58 am
You can buy modified 930's with 28-deg of motion (they add 3-deg), but they ain't cheap. That's about the most you'll get out of a standard V-dub axle.
Given a "Z" axle length, doing the math...
Z = 14": Sin28 x 14" = ~6.5" of travel each direction (total of 13").
Z = 16": Sin28 x 16" = ~7.5" of travel each direction (total of 15").
Z = 18": Sin28 x 18" = ~8.5" of travel each direction (total of 17").
Z = 20": Sin28 x 20" = ~9.5" of travel each direction (total of 19").
PostPosted: Thu Feb 06, 2014 9:59 am
Type II 25 degrees? http://www.thesamba.com/vw/forum/viewtopic.php?t=266658
I am sure if you take any of them apart you can figure out what the limit is and where to grind to provide more clearance and get more angle.
PostPosted: Thu Feb 06, 2014 8:46 pm
DMoney...got a lead on where to find those axles? I want to do it as a porsche 930 cv if possible. Also, I decided to convert the fl350 I already have with this mod for now. Not a pilot. Also, any leads on what trailing arms would be good for this mod? A link would be great.
