It is currently Tue May 13, 2025 11:55 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
 Post subject: Re: 583 swap
PostPosted: Thu Mar 13, 2014 11:59 pm
nitrosport_5 wrote:
I thought all his engines were "rebuilt"
Everything in my kit was from farr but the motor (( Internal Combustion Engine ? )). I found it on craigslist here in the OC.
PostPosted: Fri Mar 14, 2014 1:08 am
halorising wrote:
Everything in my kit was from farr but the motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)). I found it on craigslist here in the OC.
oh gotcha. you were just trying to be cheap haha.
PostPosted: Fri Mar 14, 2014 2:22 am
nitrosport_5 wrote:
halorising wrote:
Everything in my kit was from farr but the motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)). I found it on craigslist here in the OC.
Yup
I think mine is shitty also I hear some noise
PostPosted: Fri Mar 14, 2014 9:51 am
That sucks your 583 is toast. But when sh!t breaks, it always presents an opportunity for UPGRADE!
PostPosted: Fri Mar 14, 2014 9:52 am
B S wrote:
nitrosport_5 wrote:
halorising wrote:
Everything in my kit was from farr but the motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)). I found it on craigslist here in the OC.
Yup
What kind of noise?
Run the Engine have someone hold a rag over the exhaust to kill most the sound see if you can pinpoint also get out the stethoscope and listen.
PostPosted: Fri Mar 14, 2014 10:44 am
one of the best tools ever and even a cheap one works great. a long screwdriver pressed up to your ear even works.
PostPosted: Fri Mar 14, 2014 11:46 am
B S wrote:
nitrosport_5 wrote:
halorising wrote:
Everything in my kit was from farr but the motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)). I found it on craigslist here in the OC.
Yup
What kind of noise?
i think its the crank rods or its piston slap(could be has the oem pistons) but really think its the rods
PostPosted: Sun Mar 16, 2014 9:05 am
Did you have room for the stock bracket with CDI (Capacitor Discharge Ignition) and electronics on the frame rail using the 583? Any pics?
PostPosted: Sun Mar 16, 2014 5:13 pm
I don't have the stock cage but on steves pilot there was. We use the CDI (Capacitor Discharge Ignition) from the Skidoo and it didnt fit the pilot bracket. You will need to make a mount.
PostPosted: Wed Mar 19, 2014 7:45 pm
Do you guys have any pictures of the mounts you made for the CDI (Capacitor Discharge Ignition),throttle cable radiator and such please?
I am going to do the 583 kit and could use any to all photos if you could, thanks!!!
PostPosted: Wed Mar 19, 2014 8:38 pm
I found the 4 wire regulator fits in the factory location on a pilot. The CDI (Capacitor Discharge Ignition), I welded nuts to the frame so it sits in the same location as on am fl350. Check my Alabama pilot wreck to see a lot.
PostPosted: Sun Mar 23, 2014 8:51 am
Thank you for the help, will use the link for the build.
Registered users: Google [Bot], Lanix, Q, redskinman, Rppjr, scpilot66, socalgii
