It is currently Sat May 10, 2025 11:40 pm
 Post subject: Sticky clutch
PostPosted: Sun Feb 15, 2004 1:23 pm
I've got Artic Cat clutches. The drive clutches, main and spare have scrapes/gouges in the "towers" where the inner part of the triangular "thingie" rides up and down. Some of the gouges are so deep that they are causing binding. I have taken them apart and smoothed things up. Is there a better way to keep the problem from occuring? Are there some "rollers" instead of the "sliders"? Thanks for any ideas.
PostPosted: Sun Feb 15, 2004 3:22 pm
Got pictures?
The main problem I think is (without laying hands on the parts) is the dirt getting
into them the Comet 102 and 108 clutches suffer from the same problem, is there
any way you can make a belt guard that is sealed like the Polaris quad then install
a electric blower to blow clean air into the guard to keep it cool.
The clutches are good clutches but they were never intended to be used in the
dirt, on a snowmobile it is usually clean under the hood so clean that sleds never
use to use air filters on their engines...
PostPosted: Sun Feb 15, 2004 8:12 pm
Hey Jerry,
There are a few companys that offer roller conversions for the drive clutch but I can't remember if you have a 3 or 4 cams, I think it's a nine tower clutch but can't remember! (9 tower would be nine screws on the cover plate!)
Hoser is right about the dirt thing and I think the roller is the best route but at a cost.
A complete roller 4 cam Comet clutch is over $700.00 Prolly worth it but that initial cost is hard to swallow!
PostPosted: Mon Feb 16, 2004 12:07 am
I already cleaned them up and polished them. Packed away the spare and installed the other one, so pics won't show anything.
It clearly looks like dirt/sand is the culprit, the gouges look like grains of sand got in between and traveled up and down a few times.
Mine are the nine tower, with the triangle set-up. Yikes, 700 hundred bucks for a roller clutch, but then I probably wouldn't need a spare for when the first one is down, and the cost of two of them is about that amount.
PostPosted: Mon Feb 16, 2004 12:43 pm
You can get a roller clutch off of ebay for a lot less than $700...
But I don't think a standard roller clutch will solve your problems....
As moskito pointed out a while back, the Arctic Cat roller clutches are not designed to be run in sand or dirty conditions.
Solution - AAEN (and others I assume) make replacement rollers and ramps out of hardend steel.
I have purchased one of these kits used off of ebay for around $120
(I have yet to install and test it)
I belive moskito also runs one of these on his desert car.
He should be able to answer any questions you might have about them.
GoodLuck
Later
Dennis
PostPosted: Mon Feb 16, 2004 12:57 pm
GoodLuck
Later
Dennis
You know he is talking about his drive clutch right?
PostPosted: Mon Feb 16, 2004 1:04 pm
Yeah, drive clutch is where I'm having problems with wear/scraping. As said before, these are not designed to use in dirty conditions.
Anyone have a link for the AAEN??
PostPosted: Mon Feb 16, 2004 1:06 pm
http://www.aaenperformance.com/
don't be looking at that Scrambler 500 page heh
PostPosted: Mon Feb 16, 2004 4:42 pm
OH CRAP...
It must be a Monday...
You can just ignore my post and I'll go back to my corner now...
BTW - How is your secondary holding up ?
You running the nylon rollers or the steel ?
Later
Dennis
 Post subject: Comet clutch cover
PostPosted: Mon Feb 16, 2004 5:24 pm
Does anybody know where to buy the covers for the comet 102c clutches?
I have a cover on my curent 102c but would like to have a source for the future.
Well at least you (FL670R) didn't call hoser an asshole and say he is up to his same old sh!t when he pointed out a simple error!
Whew!
I was begining to think the entire free world would dog pile on the hoser any time he countered someone elses opinion, whether it be right, wrong , or indifferent.
File comment: Comet 102c clutch cover on FL350 Engine.
PostPosted: Mon Feb 16, 2004 6:10 pm
Hare here is a site for you. www.hoffcocomet.com
Also i have a old parts sheet from Sara at EEE and it is showing a kit for a 102c (dust cover can) This catalog is so old i would call and get a newer one EEE phone is 8oo-763-3762 or 760-788-7802 have fun at that web page trying to find stuff
The spring guides are great info just hard to find lol
PostPosted: Mon Feb 16, 2004 9:59 pm
I asked on the snowmobile forums and I only recieved one reply so far, here you go!
High Performance's catalog. their # is 1-800-451-5268
Let me/us know!
Registered users: Bing [Bot], FL670R, Google [Bot], Kuma, Lanix, PilotJunkie_87, rmesser
