It is currently Sat May 04, 2024 10:23 am
PostPosted: Mon Apr 28, 2014 12:10 pm
mr2angry2 sent me another one of his Pilot engines while I was on vacation so when I got back I started the CSI, it only took me 5 days to remove the cylinder :shock: I never had a cylinder this hard to remove before, patients, persistence and PB blaster paid off in the end, after soaking it with PB blaster then trying to get the cylinder to move 3x a day for 5 days it finally came off with no damage to the parts and no caveman damage like trying to pry it apart with a screwdriver lol
About as caveman as I had to go was taking a plastic dead blow hammer and tapping up on the exhaust flange and tapping up on the reed cage, over and over a few hundred times, I also removed the head and put a rag between the top of the piston and the head, when you try to rotate the crank shaft the rag compresses between the head and piston then it tries to lift the cylinder off the crank cases.
PostPosted: Tue Apr 29, 2014 12:43 am
Looks like it just has to many miles, worn out rings??
PostPosted: Tue Apr 29, 2014 7:44 pm
Stock top end?? Looks like it will need some new base studs??
That's crazy how stubborn the cylinder was
I send you my stuff because I know you take care of it
Anyone else would of chiseled the heck out of it to pull up
Does it look like it was ever apart??
PostPosted: Wed Apr 30, 2014 12:41 pm
It appears to me that its never been apart and everything is original, probably the reason why it was so hard to get it apart, I had a hard time splitting the crank cases but everything looks ok, the crank is in great shape I did end up destroying both the cylinder dowels removing they were rusted in and one of the crank case dowels because it was rusted in place, I gave the cylinder a light hone and its in great shape just needs a new standard piston kit, I cleaned up the base studs but most all the coating on them is gone while they might look good they will rust easily in the future since that coating is gone, camera is in the shop will post up pics later.
Below is what I will need.
Standard bore piston kit (piston, ring, circlips, wrist pin, wrist pin bearing) It looks like Honda still has some std pistons left but no rings, what other Honda application had the same size bore that was 2 stroke that might have the rings also OR how about another mfg that used ART pistons with the same bore I wonder if they will fit ? Any 80mm 2 stroke ART rings will fit?
For example Prox 2 stroke pistons are made by ART so I wonder if they will work, maybe a call to prox would get an answer? http://www.shop.pwcxtreme.com/PRO-X-KAW ... P4480R.htm
Two cylinder dowels 94301-12200 http://www.partzilla.com/parts/detail/h ... 12200.html
One case dowel 90701-HE0-000 (says discontinued) Looks like this one is the same and cost 1/2 as much http://www.partzilla.com/parts/detail/h ... 9-000.html 90701-399-000 PIN, DOWEL (10X28) Order 6 of these I will pay you for them I might as well stock some
4 Cylinder studs 92900-10045-3B http://www.partzilla.com/parts/detail/h ... 45-3B.html Order 8 of these I might as well stock these also
More later... Added pics of the bad dowels and the cylinder studs
File comment: .
Cylinder dowels
File comment: .
Stubborn case dowel
File comment: .
To give you an idea a new stud next to yours.
File comment: .
After cleaning up on wire wheel
PostPosted: Wed Apr 30, 2014 9:58 pm
Thanks for the info I will do some research
PostPosted: Wed Apr 30, 2014 10:09 pm
Probably a stupid question but if I can't get a oem setup ,,will the 80 mm wiseco kit work?)
PostPosted: Thu May 01, 2014 7:11 am
Also there are piston A. B and. c from honda
No rings,,,bearing or pin available
PostPosted: Thu May 01, 2014 12:18 pm
If your placing an order with Honda I will also need one each of the following bolts, actually you will be needing one of them I am just not exactly sure what one.
95701-06095-00 BOLT, FLANGE (6X95) http://www.partzilla.com/parts/detail/h ... 95-00.html
90011-PA0-000 BOLT, FLANGE (6X93) http://www.partzilla.com/parts/detail/h ... 0-000.html
95700-06100 BOLT, FLANGE (6X100) http://www.partzilla.com/parts/detail/h ... 06100.html
95701-06090-08 BOLT, FLANGE (6X90) http://www.partzilla.com/parts/detail/h ... 90-08.html
PostPosted: Thu May 01, 2014 12:31 pm
YES that would work fine also.
PostPosted: Thu May 01, 2014 1:10 pm
Might have to get a wiseco kit unless someone on here has a set. I'll give it a couple days ,,
80 mm kit right?
I can also place the partzilla order for those bolts and dowels you needed etc
Are you all done tearing down? I won't place order til I know I'm in the clear
PostPosted: Thu May 01, 2014 7:54 pm
Just found 4 base studs from last order in my stash and the 2 cylinder dowels
Did you need 8 studs for your self or were 4 going to be mine??
Were u needing 6 spare dowels for yourself or were u including my 1
PostPosted: Thu May 01, 2014 8:07 pm
4 Studs were going to be yours, 5 of the dowels I was going to keep for stock and use one on your Engine.
PostPosted: Mon May 05, 2014 10:41 pm
Parts are ordered from partzilla!!
PostPosted: Wed May 28, 2014 9:09 pm
Did the parts package ever make it to you ???
PostPosted: Sun Jun 01, 2014 3:39 pm
Yeah buddy and your Engine is done and ready to ship tomorrow :-)
Hoserized the cases, lapped the gasket surfaces to ensure they are flat, installed new bearings and seals, new std wiseco piston, rings, wrist pin, clips, the reeds are in great shape, intake manifold is still pliable no cracks.
PostPosted: Sun Jun 01, 2014 3:44 pm
Honed the cylinder, removed a bunch of the casting flaws they should have removed at the foundry before shipping to Honda, this will help thing flow much better, beveled the ports, prepped the piston, head is nice and flat.
PostPosted: Sun Jun 01, 2014 3:45 pm
Did you remove the dowel pins that go in the cases for the Engine mounts both are missing?
PostPosted: Sun Jun 01, 2014 9:47 pm
Looking good !! You do such a nice job
I think I removed them I did cause they were loose . If they were t there then I must have
Let me know when your all packed..and I'll send payment
please pack the extra gaskets into the box too
This time I'll just have to repay you for the FED EX. .
PostPosted: Mon Jun 09, 2014 8:50 pm
Received Engine today
Looking good
Thanks again
Usps didn't bust it up like UPS
PostPosted: Tue Jun 10, 2014 5:03 am
Looking good
Thanks again
Glad it made it ok, I think its a crap shoot any more with shipping, I hate all shipper just about equally now.
You say anything about the condition you receive a package in the shippers claim you didnt pack it right then they get the most stupid look on their faces when you tell them "the box was brand new and in brand new condition when you accepted the package and took the money, you said nothing about the package not being right when accepting the money and gave a receipt, you do this shipping thing for a living correct? ALL the damage to the package was done when the package was in your care and custody not ours! How again are all these damaged packages out fault? "
PostPosted: Tue Jun 10, 2014 2:01 pm
Looking good
Thanks again
if i ever shit a Engine that has to come back to me ill use a ice chest to protect it
PostPosted: Tue Jun 10, 2014 2:10 pm
That's got to hurt lol
PostPosted: Tue Jun 10, 2014 8:02 pm
I've heard of guys shipping in a small cooler which I debated on but I took the chance and they arrived back in good shape no damage yet!! Ups was the only close call
Fed ex or usps were the shippers that didn't damage the shipments
Registered users: Bing [Bot], Google [Bot], Q, wyeeoddy
