It is currently Sun Apr 28, 2024 6:44 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Sep 18, 2014 5:31 am
well as most of you have seen i have decided to convert my pilot to a ROTAX
I'm using a 617 ROTAX i picked up in a 1991 skidoo mach 1 paid $250 for the sled
its a 617cc rave Engine (the 670's little brother only 50cc less ). the Engine puts out 109 hp
i bought the farr off road(nitrosport_5 made it ) mount already done welding/installing it
i have to make the chamber pipe , fuel tank and belt guard/cover
was going to make a new wiring harness but then realized that that was going to be a pain in the ass lol
will post photos tomorrow
I just started working 7 days a week at work have very little time to work on the pilot
also trying to find a new truck looking for a dodge diesel around 15-20k tops 5,9 or 6.7 2005 and up to 08
i already have the Engine ,carbs ,radiator, starter,clutch,and regulator.
upper radiator mount and grommets are on order
PostPosted: Fri Sep 19, 2014 4:39 am
PostPosted: Fri Sep 19, 2014 2:39 pm
Looking good, so how long before its first test run?
PostPosted: Fri Sep 19, 2014 6:26 pm
Probably over a month or two
PostPosted: Fri Sep 19, 2014 11:19 pm
lots of fun!! I love mine. the only thing I don't like is how loud it is. I swear it could make my ears bleed!!
the wiring is pretty easy. 2-3 hours max
PostPosted: Fri Sep 19, 2014 11:36 pm
The wiring ain't going to be hard just going to splice into the factory harness
You bought the farr off road kit correct?
PostPosted: Tue Sep 23, 2014 2:35 pm
yes i did buy the complete Farr kit.
i also tapped into the factory harness. i use the factory kill switch without a relay. i cut and connected the wires going to the factory switch to remove it fromt he OEM circuit. i then connected one side of the switch to ground and one side to the rotax stator. now my machine will run in "off" and die in "run. easy enough. i also mounted a 3 wire rotax regulator in the OEM spot and tapped it into the factory harness.
PostPosted: Tue Sep 23, 2014 2:55 pm
Help me get into the mind of a pilot/rotax builder:
For the life of me I can't understand why someone would hack n wack a pilot.
I don't own a pilot but I think Honda got it right when they built it. Liquid cooled and a clutch on the Engine so that when you come off a jump at full throttle and land you don't split the gearbox unlike the fl350. I can understand a hack n wack on a fl350 because of all of the issues with this machine but why hack n wack a pilot ?? If you say you want more power why not build a machine from scratch ?? There are not to many dumb dumbs on this site. It appears everyone is mechanically inclined but may not have access to a welder, milling machine or lathe like me so that would be the only draw back for some in building their own machine. I was reading here on one of the threads where they said "check your frame for cracks" :shock: Why create yourself a problem ?? I would love to own a pilot but couldn't find any two years ago when I was looking so I bought two fl350. It has been a steep learning curve but it has been fun. May build my own machine with a rotax one day.
PostPosted: Tue Sep 23, 2014 3:39 pm
because we can? there is nothing hacking the pilot about it. Like mine for example, pulled out the factory Engine, wire harness and anything else didnt cut the leads off of anything like the steering wheel, lights ect. built a new harness from scratch and used an old burnt up harness for the plugs to plug into the kill switch and all of that. if i really wnated to and had the stock motor (( Internal Combustion Engine ? )), in a day i could have it back to stock. all of the factory mounts are still there. Only thing cut out was the radiator mount, but that is moved alot of the time anyways.
find someone with a stock pilot, and them come ride my 670 pilot. you wont be asking this question anymore. I could build my own machine from scratch but don't want to put the money into them. I have bought my 2 pilots for dirt cheap, one with no motor (( Internal Combustion Engine ? )) and one that was sitting for 10-15 years in a field. I brought them back to life. most would have parted them out. They were pretty far gone.
another thing i would like give for a reason to swap the Engine, have you priced out pilot Engine parts? They are only going to get harder to find. with the rotax you have 3 or more different manufacturers to choose from for about every single part. Its a no brainer in my eyes. More reliable power, cheaper parts, can go to any local snowmobile shop and get parts to rebuild it.
PostPosted: Tue Sep 23, 2014 3:51 pm
because we can? there is nothing hacking the pilot about it. Like mine for example, pulled out the factory Engine, wire harness and anything else didnt cut the leads off of anything like the steering wheel, lights ect. built a new harness from scratch and used an old burnt up harness for the plugs to plug into the kill switch and all of that. if i really wnated to and had the stock motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)), in a day i could have it back to stock. all of the factory mounts are still there. Only thing cut out was the radiator mount, but that is moved alot of the time anyways.
find someone with a stock pilot, and them come ride my 670 pilot. you wont be asking this question anymore. I could build my own machine from scratch but don't want to put the money into them. I have bought my 2 pilots for dirt cheap, one with no motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) and one that was sitting for 10-15 years in a field. I brought them back to life. most would have parted them out. They were pretty far gone.
When I asked the question what I was thinking about someone with a running pilot, yours were rescued. But you do have a valid point about the parts. I guess I would some what agree here.
My next question is: Would you split your gearbox if you landed full throttle ??
PostPosted: Tue Sep 23, 2014 5:28 pm
because we can? there is nothing hacking the pilot about it. Like mine for example, pulled out the factory Engine, wire harness and anything else didnt cut the leads off of anything like the steering wheel, lights ect. built a new harness from scratch and used an old burnt up harness for the plugs to plug into the kill switch and all of that. if i really wnated to and had the stock motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)), in a day i could have it back to stock. all of the factory mounts are still there. Only thing cut out was the radiator mount, but that is moved alot of the time anyways.
find someone with a stock pilot, and them come ride my 670 pilot. you wont be asking this question anymore. I could build my own machine from scratch but don't want to put the money into them. I have bought my 2 pilots for dirt cheap, one with no motor (( Internal Combustion Engine ? )) ((Internal Combustion Engine?)) ((Internal Combustion Engine?)) and one that was sitting for 10-15 years in a field. I brought them back to life. most would have parted them out. They were pretty far gone.
I doubt it. Probably will grenade that slipper clutch before the transmission. But doing it enough sure. Same with. stock pilot. If you mistreat it enough somthing has to give.
PostPosted: Tue Sep 23, 2014 5:32 pm
because it doesn't have enough power after riding in my rotax fl350 lol
and like matt said rotax parts are cheaper that pilot parts
look at halo he has had stock pilots ,cr500 pilot, 583 pilot and now he installed a 670 in his pilot just because of the power
im doing it for more power
and i don't think of it as hack n wack
im not some guy that's going to have my exhaust ,tank ,carb or anything sticking out the side or back of the rig
I'm doing it right, so it will look good.
+ theres other stuff i might do to the pilot :-)
PostPosted: Tue Sep 23, 2014 5:41 pm
Jordan higgans ran a 583 pilot with no oil in the trans it lasted a couple of days lol
That's with no oil
All I would worry about is the slipper clutch but that's if your going to be a idiot
PostPosted: Tue Sep 23, 2014 6:27 pm
That's with no oil
Hey now I fried a clutch pack. But wheelies were fun :)
PostPosted: Tue Sep 23, 2014 7:09 pm
nitrosport_5 wrote:
That's with no oil
Lol I mean like being a jackass driver?
PostPosted: Sat Oct 04, 2014 8:48 am
well I'm waiting on time to start installing my radiator
got the mount kit last week
I'm trying to find a pipe bender so i can bend my mount parts
PostPosted: Tue Oct 07, 2014 8:50 pm
This is why we went with the 670..
PostPosted: Tue Oct 07, 2014 8:55 pm
Hell Im now looking at a etec 800
PostPosted: Tue Oct 07, 2014 9:00 pm
just buy the one I sent you the link to
PostPosted: Thu Oct 30, 2014 3:35 am
well got the radiator mounted :-)
PostPosted: Mon Nov 03, 2014 8:26 am
That's ONLY 5 words man! :shock: ...But a picture paints a thousand. :-)
PostPosted: Tue Nov 25, 2014 6:12 am
For baz
PostPosted: Tue Nov 25, 2014 6:21 am
Got the hoses all done
Like my custom elbow?
Lots of stuff to do still
finish welding the radiator mount
Make a coil and CDI (Capacitor Discharge Ignition) mount
Splice the regulator into the harness
Mount the fuel tank
Wire the fan into the harness
Figure out what wire is the kill to the CDI (Capacitor Discharge Ignition) off of the stock Engine
Just need more time and $$$ lol
Mostly More time than $$$ lol
PostPosted: Tue Nov 25, 2014 7:50 am
Looks great Bran,can't wait for roostin'...wheelien'vids...they speak even more words than pics! :shock: :-)
PostPosted: Tue Nov 25, 2014 11:12 am
Looking good you going to have this monster running by this season?
Registered users: Bing [Bot], Google [Bot], liduno
