It is currently Fri May 16, 2025 8:42 pm
PostPosted: Wed Jan 28, 2015 12:17 pm
Hello to all,
I have taken my LT pilot completely apart and the frame is worse then I had expected, all in the left front, I have decided to sell the Lower frame and entire LT kit minus axles and rear shock hoop supports. The hoop supports are the small bars that run from the rear shock hoops to the down tubes and then another small bar welded in between the rear down tubes.
Here is a list of what it will come with,
Bare lower frame (no title) with all LT and bump steer mounts, bump steer kit with stabilizer and all tie rods, front upper and lower swing arms, front shocks Both in great shape, they were rebuilt by atvr a couple of years ago and have seen very little use, rear radius arms, rear lower control arms, 3 rear upper swing arms ( I have an extra one, I replaced the left rear with a new one because I did not like how far the ball joint went in to it.), rear shocks, they are both in great shape but the left rear will need new seals, I sent them off to atvr thinking that they would replace the seals in all the shocks but when I got them back they had not replaced the seals in the left rear, I called and Niel told me that they usually only replace seals that show signs of leakage and if they look good they only service the shock with new oil.)
$2400.00 no fees on payment. Shipping is the buyers responsibility, I will help in any way I can. I am going out to California in March, if it is along my route I could deliver for no extra charge.
I have ran this machine with the bent frame and had no problems, honestly it flat out halls butt and handled great. I did not realize the frame was this bad until I took it apart.
The only things you will need to complete the kit are axles and rear shock hoop supports.
Please PM me if you are interested.
Thank you.
PostPosted: Wed Jan 28, 2015 3:37 pm
Blows me away honda put no suport at all on the bottom of the frame. On the other side that frame could have been made that way. I have not come across a frame yet that is the same. Good luck on the sale
PostPosted: Wed Jan 28, 2015 4:26 pm
Thank you Sir.
Can you do anything to strengthen them up in that area?
PostPosted: Wed Jan 28, 2015 6:36 pm
I have a straight lower frame and semi straight(LOL) upper frame..no title..
GAPILOT
PostPosted: Fri Jan 30, 2015 3:32 am
have welder can weld.....how strong you want it?? I can make it where a M1 tank wont bend it lol...of course I can Steve but on top of everything else yes I believe we can
PostPosted: Fri Jan 30, 2015 6:26 am
scpilot66
can you straighten it
what about putting it on a car straightening Gig a good panel bloke should be able to sort it
cheaper then a new frame + work
just a though
A
PostPosted: Fri Jan 30, 2015 11:32 pm
Porto power and blocks of wood in the corners so the Porto power doesnt cave in the gussets
I fixed mine like that
Also had to straighten a diamond out of it,,used a car frame straightener for that
Used measuring tape to measure diagonally across the frame section ..little by little it will square
PostPosted: Sat Jan 31, 2015 7:16 pm
wyeeoddy wrote:
scpilot66
just a though
A
Thank you guys for the advice, I was going to put it back together for my son but I need to sell it.
Take care.
PostPosted: Wed Feb 04, 2015 12:22 am
Sold.
Thank you.
Registered users: Baidu [Spider], Bing [Bot], c5racer, Google [Bot], MassOdy
