It is currently Tue May 20, 2025 1:59 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Post subject: my new pilot.
PostPosted: Sat Apr 04, 2015 8:45 pm
Just picked her up today. I have 3 350s but this is my first pilot. I'm excited and eager to tear into it but ill have to finish my longtravel 617 first. It will definitely need some love. The cage has some horrible repair in it and I Dred heats under the foam. But the plastics are in good shape and it starts up right away. Fresh wheels, tires, brakes, and a roll cage rebuild it should be pirty nice. 3.5 he drive and 3k she's mine. Definitely not the cleanest pilot but finally one in my pricerange. It's missing a air box lid and snorkel, front bumper, mirror. And yes this was the one on ebay.
 Post subject: Re: my new pilot.
PostPosted: Sat Apr 04, 2015 8:52 pm
Some repair job..........
PostPosted: Sat Apr 04, 2015 8:54 pm
Congrats :-)
not a bad pickup for 3 grand
PostPosted: Sat Apr 04, 2015 9:12 pm
I've been looking for a while but I never see them for less than 4500.
PostPosted: Sat Apr 04, 2015 11:33 pm
Congrats on the new addition. -::
PostPosted: Sun Apr 05, 2015 1:09 am
I don't think it has many hours on it it appears to have the original drive belt. The suspension and steering is very tight.
PostPosted: Sun Apr 05, 2015 9:33 am
Ask the former owner who made the seat cover looks like a pretty good job.
Looks like a good deal to me.
PostPosted: Sun Apr 05, 2015 10:07 am
I asked him if it had been recovered before I headed to pick it up. He said he didn't know. So it wasn't him who had it done. It is nice and soft. I didn't realize how much more room the pilots have.
PostPosted: Sun Apr 05, 2015 12:43 pm
It's missing the airbox lid does this bracket have anything to do with that or is something else missing?
PostPosted: Sun Apr 05, 2015 1:02 pm
That's the bracket for your missing radiator over flow tank.
PostPosted: Sun Apr 05, 2015 1:52 pm
Ah thank you another part to add to the list
PostPosted: Sat Apr 11, 2015 10:11 pm
I knew I'd find something hiding under that foam. Wow sweet repair!
PostPosted: Sat Apr 11, 2015 10:28 pm
Front bars
PostPosted: Sun Apr 12, 2015 10:35 am
WOW
PostPosted: Sun Apr 12, 2015 11:54 am
Yea I think its old bed frame.
PostPosted: Sun Apr 12, 2015 12:56 pm
Nice score! Maybe the previous owner likes to flip it so he braced the areas that like to bend on a rollover??
Be sure to oil the K&N filter and get a outerwear for it, I run open box filters like that but drilled three or four 1" holes in the bottom of the air box to let the dirt and sand escape the bottom of the box. Compression ok?
PostPosted: Sun Apr 12, 2015 1:06 pm
Repairs look like a typical home brew back yard hacker repair, not great looking but probably one of the safer repairs I have seen made to frames. Not cosmetically pleasing and weight minded but might have been all that was in the reach of the owner at the time.
All these frames are bent up they are made from bent up tubing at birth I doubt their is a single Pilot that would fit back into the factory jigs today, whats important is safety and how they roll, roll it on pavement and see how easily it rolls going straight that is where most my concern would be, get the time and funding then correct the past repairs go for it.
PostPosted: Sun Apr 12, 2015 1:09 pm
Pull the air box assembly out from the carb, post up some detailed as found pictures of the inside of the filter and the tubing that goes from the air box to the carb, post detailed pics of the intake side of the carb and carb slide, remove the carb slide and post pics of the carb slide. This inspection is a must for any used ATV.
PostPosted: Sun Apr 12, 2015 3:09 pm
Im replacing the tubing today. The compression was 125 cold. It's definitely running rich. Good thing too because the previous owner ran 50-1 mix. I'll post some more pics as I go. Don't plan to ride until I'm satisfied she's ready.
PostPosted: Sun Apr 12, 2015 4:19 pm
That's better
PostPosted: Sun Apr 12, 2015 8:51 pm
Got the main section straightend out. Built 3 of the down tubes and ran out of material.
PostPosted: Sun Apr 12, 2015 9:21 pm
That tube repair looks much better nice work.
PostPosted: Sun Apr 12, 2015 9:57 pm
Yup, nice job.
Now ride that bitch! :-)
PostPosted: Sun Apr 12, 2015 10:43 pm
Ran out of paint too! The previous owner armorall'd the crap out of it so I keep getting fish eyes in the paint. Even after several wipe downs with brake thinner.
PostPosted: Sun Apr 12, 2015 10:47 pm
jknarfal wrote:
It's definitely running rich. Good thing too because the previous owner ran 50-1 mix. .
nothing wrong with 50:1 as long as it's good grade of oil, I run AV gas and 50:1 golden spectrol for about 30 years, never had a lubrication issue, well there was that one time when a big end rod bearing went south but I had tried adding something to the fuel which i attribute to that. Run what works for you, tune your engines for it and don't change. "if it works, don't fix it"
Registered users: Bing [Bot], c5racer, Google [Bot], rmesser, wyeeoddy
