It is currently Fri May 16, 2025 4:57 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: MobTech_Photo FL350
PostPosted: Wed Dec 24, 2014 10:10 pm
Mobtech_Photo wrote:
fully wrote:
any binding of the u-joints with the new shocks
Have not checked yet, as I had smaller bolts, which let it drop farther out. The shock is about 1/2" longer than the stockers. Putting limiting straps on it, to prevent pulling the shock apart, like the stocker.
WARNING!
Don't use limit straps to keep the U joint from binding if the shock is too long. Limit straps stretch!
PostPosted: Sun Dec 28, 2014 1:39 am
A new shock mount is being created that moves the shock up and will give even more room = less u-joint stress.
I will post updates, as it comes along.
PostPosted: Thu Jan 01, 2015 2:47 am
Progress
PostPosted: Thu Jan 01, 2015 7:48 am
? How much stroke / travel do you have with that New Shock. The reason I am asking if the stoke is close or the same as the old stock shock
with the shock moved up you might have major problems with the frame bottom out If the shocks aren't sprung and valved right.
Why I asking this when I fitted my YSS shocks they were 1/2 longer Eye to eye but had a extra 3/4" travel
I had to adjust the toe in to stop binding on the Uni joints under full compression but just enough so the
Uni joint would not bind on full droop (( unsprung weight )) it is a fine line.
Also looking at the last pic is the top bolt pressing hard onto the body / top of the shock as it need to be able to move
on the Eye of the shock if so you will snap bolts or the head of the shock
PostPosted: Thu Jan 01, 2015 7:24 pm
The shocks have about 1/2" more travel and thank you for the heads up on the toe adjustment. I will look into it.
I am using different washers, the others were for mock up, and the top heim now has some room to swivel.
PostPosted: Thu Jan 01, 2015 7:25 pm
Snow in my backyard for the first time in my life.
PostPosted: Mon Mar 23, 2015 6:55 pm
Trip out to Ocotillo Wells. Second video, I pushed it a little more. Drove around for about 3 hours with no problem. After a flat tire, a pull apart rear shock and several fouled plugs. It was great to get some actual quality riding time. I had so much fun and it makes the work all worth it.
https://youtu.be/v07c66OJzY8?list=UU8_L ... cWXMSsIDSw
https://youtu.be/jjPN7_elS8Q
PostPosted: Mon Mar 23, 2015 7:21 pm
Looks like a good time glad to see your up and running again, whats up with the fouled plugs? Any excessive smoke or sputtering at a certain rpm ?
PostPosted: Tue Mar 24, 2015 12:59 am
I was using a sub-part 2 stroke oil, Valvoline for lawn equipment upon further review of the label. Using Honda HP2 now and it is running like a champ.
PostPosted: Sat Jul 04, 2015 4:44 pm
Just got the rear shocks rebuilt and now they are amazing. Some adjustment still needed on the preload adjuster. I think I set it up a little hard and was too lazy to change it in the dirt, with a bottle jack. So I took the odyssey out to Lucerne last night. Went pretty well other than finding a 2ft deep 5 foot wide ditch in the middle of the night. Lights were focused in the distance as I came around a corner and hit the front bumper on the far side of the ditch. Before I knew it I was looking at dirt and the buggy was sitting on the front two bars of the rollcage. Then fell to the side when I was getting out. I was very happy for the harnesses and beard seats. Needless to say, adrenaline was pumping and did not sleep much. Everything seems to be working correctly and just cosmetic damage. Not more pretty red fenders, little damaged now.
Image[/url [url=http://s318.photobucket.com/user/Jeepspeed3722/media/Honda%20Odyssey%20FL350/090ecea8-b9bf-4735-9c3b-bd2a672f3b4d_zpsgt8choxb.jpg.html]Image[/url [url=http://s318.photobucket.com/user/Jeepspeed3722/media/Honda%20Odyssey%20FL350/ef537d64-0cd3-444d-ac32-a895c906427f_zpsrve8ag4y.jpg.html]Image
PostPosted: Sun Jul 05, 2015 3:50 pm
PostPosted: Thu Aug 13, 2015 1:45 pm
What year/model were the shocks out of. Did they change anything when they rebuilt them?
Nice upgrade over the stockers?
PostPosted: Sun Nov 01, 2015 9:54 pm
The shocks on the rear of the odyssey are front shocks off a '99 Polaris XCR 440 snowmobile. I had them rebuild. They are awesome, but do not quite fit in the stock location. A tad long, about 1/2".
I am sure you are talking about the rear shocks, but the front ones are off a trx425. I have not rebuilt them.
PostPosted: Sun Nov 01, 2015 10:37 pm
Seems like the rear isn't worth screwing around with. I have wanted the front changed to A-arms and I like the stance it gave your machine.
PostPosted: Mon Nov 02, 2015 2:31 am
Quote: Snow in my backyard for the first time in my life. :shock: You poor bugger. You mean you have never played in the snow ?? :shock: You poor bugger.
Was looking at your rear shock set up. Question: You seem to have a lot of adjustment left on the spring preload so what I want to know is why didn't you try to cut 1/2" off of the shock shaft and rethread the end to screw on the head ?? Then bring back the preload to accommodate. That's a lot of work to redo the shock mount because the shock is 1/2" to long. Just curious.
PostPosted: Mon Nov 02, 2015 12:32 pm
If you're not needing to screw around with the rear then you must be running works shocks already.
If not, then you have no idea what you are missing out on. The weakest point in the Ody's suspension is the rock hard rear Showa Pogo Sticks, that Honda used as a shock.
PostPosted: Fri Nov 11, 2016 11:22 pm
Getting ready for the Lake Elsinore Grand Prix. Wish me luck on Sunday.
PostPosted: Sat Nov 12, 2016 12:22 am
Good Luck for sunday...No pressure...No pressure... Image
PostPosted: Sat Nov 12, 2016 10:27 pm
https://youtu.be/DxqoL8n8pxk
PostPosted: Sun Nov 13, 2016 10:07 am
Good luck!
Will you get any in car video?
PostPosted: Sun Nov 13, 2016 4:08 pm
Best of luck... Win or loose you are out there having fun! I'm jealous, nothing like that back here on the east coast.
Someone prove me wrong. :-)
PostPosted: Wed Nov 16, 2016 11:49 pm
PostPosted: Wed Nov 16, 2016 11:51 pm
Had some Engine trouble and missed the race, but did get some video during practice.
https://youtu.be/p-Djz6WH91U
PostPosted: Thu Nov 17, 2016 9:05 am
I fixed your first attempt to post the video using the youtube thingie you added too much of the address go back and EDIT that post look at the code you will see what I mean you only need to add the p-Djz6WH91U part between the code brackets.
PostPosted: Thu Nov 17, 2016 10:47 pm
Thank you.
