It is currently Mon May 06, 2024 7:58 pm
 Post subject: 12 valve truck
PostPosted: Mon Dec 07, 2015 7:04 am
well I'm starting to gather parts for a 12 valve cummins swap into a 1/2 ton truck going to go with the sleeper vibe, ultra quiet ultra power , looks like a Piece of junk barn find
Planning on making a pulling/drag truck.
Engine is a 1996 cummins 5.9 240K miles
got the Engine, radiator, intercooler and part of the wiring harness and a blown up transmission
also have the flex plate and TQ converter
trans is a 47RE that came from a 2001 4x4 truck
first and second gear are out and the input shaft is bad
i might try and rebuild this transmission if i can
if i don't need special tools
i need to find a new transmission either a 47re or 48re ,a PCM ,wiring harness,
and a transfer case
shooing for around 400-500 HP once done
Truck will be a presmog 4x4 gas truck
Shooting for either a 74-75 k10 Chevy or a 70-75 dodge 1/2 ton maybe a ford f100 if I find one
Also been looking at a 1966 IH 1100 4X4
Been really leaning on the IH 1100 clean title non opp for a grand
 Post subject: Re: 12 valve truck
PostPosted: Mon Dec 07, 2015 10:43 am
I think we have that tranny at work. I'll look when I get in.
PostPosted: Mon Dec 07, 2015 7:11 pm
i totally forgot about the parts trucks you have at work lol
PostPosted: Mon Dec 07, 2015 8:32 pm
Sorry man no luck just looked all around and it must have been sold. I'll let you know if any more dodges come in. Does it have to be a 4x4 transmission? I know some people run a divorced transfer case. Depending on room.
PostPosted: Mon Dec 07, 2015 9:21 pm
Would rather have a 4x4 trans but unless I can't find one then I would go 2wd
Registered users: Bing [Bot], CurtisR401, eseymour72, galimberti, Google [Bot]
