It is currently Fri May 03, 2024 1:08 am
 Post subject: Drive Chain
PostPosted: Sun Mar 06, 2016 5:28 pm
Whats my best choice for a drive chain? I took the chain case apart, change the bearings and seals, and it looks like my drive chain is at the last of it's life, so might as well change it as i'm not going to want to do this all over again anytime soon. I see some choices on ebay, but can i just go to a local motor (( Internal Combustion Engine ? )) cycle shop with the old one and have one made? I understand it has to be pressed together, no master link.
It's amazing how just wanting to do some routine maintenance turns in to a complete rebuild.
 Post subject: Re: Drive Chain
PostPosted: Tue Mar 08, 2016 4:44 pm
Joker0370 wrote:
Whats my best choice for a drive chain? I took the chain case apart, change the bearings and seals, and it looks like my drive chain is at the last of it's life, so might as well change it as i'm not going to want to do this all over again anytime soon. I see some choices on ebay, but can i just go to a local motor (( Internal Combustion Engine ? )) (( Internal Combustion Engine ? )) cycle shop with the old one and have one made? I understand it has to be pressed together, no master link.
I don't see why you can't just get a chain with a master link and then instead of using cotter pins or the spring clip, just rivet it with a couple of hammers.
I am a bit of a Neanderthal sometimes but I just don't see why this wouldn't work.
PostPosted: Tue Mar 08, 2016 6:40 pm
Everything I read says to not use a chain with a master link. I'm just concerned with it letting go and ruining other parts. I ment to go out to a bike shop and ask this week, but the flu bug got me and i've been trying to kick it instead.
PostPosted: Tue Mar 08, 2016 8:29 pm
If you use a chain with a master link and the link fails.....
It completely destroys the outer cases! :shock:
PostPosted: Tue Mar 08, 2016 9:21 pm
+1 You break a chain and it is mass destruction. It was expensive to fix 20 yeas ago. I cant imagine today with them being so rare. We used to use tsubaki chains. They were the gold standard at the time.
PostPosted: Wed Mar 09, 2016 8:28 pm
I just bit the bullet and ordered a NOS Unit off ebay. Figure it will be here by the time I finally get over this flu bug.
PostPosted: Thu Mar 10, 2016 11:34 am
Good deal, you're doing it right!
Hope you get over the bug quickly so you can go play!
Registered users: Bing [Bot], Google [Bot], hoser, maseventura
