It is currently Sat May 17, 2025 11:13 pm
PostPosted: Mon Apr 18, 2016 11:09 am
I built a 64" x 40" red oak dining room table for my house. This is what I've been working on in my shop instead of buggy stuff. Wife found a farmhouse style table at PotteryBarn, but the price was WICKED HIGH like....$2k without chairs! So I built one for $650 and bought $350 of chairs. Also acquired a 6.6" joiner, 13" planar, and a commercial Craftsman table saw (my motivation for building a table, ha!) in the process.
Picked up some "real" red oak from a sawmill in SE Michigan and learned #1) it ain't cheap and #2) it ain't light.
Found some plans online, but needed a custom size to fit our fining room nook. So I drew one up in Pro/E.
In my spare evenings/mornings when kids were asleep or busy having fun, I managed to find enough hours to make this thing happen. The results were well worth the work & $$! A happy wife makes a happy house. :-)
File comment: That there is 7 coats of high build clear gloss polyurethane.
13043244_10154100386549872_5473725101570310490_n.jpg [ 38.28 KiB | Viewed 2411 times ]
12998768_10154100386859872_8551308594308030533_n.jpg [ 33.72 KiB | Viewed 2411 times ]
12994589_10154100386954872_6143741603494742751_n.jpg [ 31.78 KiB | Viewed 2411 times ]
File comment: Couple clamps...
13010624_10154100387724872_3181972940993862027_n.jpg [ 77.95 KiB | Viewed 2411 times ]
File comment: My original cad design. Only changed the gussets because my band saw didn't have enough @ss to cut arches in 2" thk oak.
File comment: Lumber (and my assistant)
12985418_10154100387869872_3492007923282075159_n.jpg [ 46.13 KiB | Viewed 2411 times ]
PostPosted: Mon Apr 18, 2016 11:57 am
Nice job!...beautiful table
PostPosted: Mon Apr 18, 2016 3:50 pm
Awesome job dude! I like heavy tables.
I used to do a lot of woodworking, but not so much lately.
Did you glue up the top or is that a purchased part?
PostPosted: Mon Apr 18, 2016 4:45 pm
Looks great. Love the finish. What did you use to clear coat?
PostPosted: Mon Apr 18, 2016 8:17 pm
Looks so nice I almost wouldn't want to eat off of it
PostPosted: Tue Apr 19, 2016 6:26 am
The top I got at Lowes. It's a 1.75" thick piece of butcher block in Baltic Birch. I trimmed to length and sanded the snot out of it.
PostPosted: Tue Apr 19, 2016 6:30 am
It's "high build" clear gloss polyurethane by minwax.
Added...
Each coat dries for at least 24hrs. Then I go over it with a #000 steel wool, let it sit another half-day (in case I uncovered any partially cured poly), tack cloth it clean, and apply another coat. Used 69-cent 4" wide foam brushes. If you rush poly-u, it can get "cloudy".
Then every couple years, you can go over it again with fine wool like #0000 and it will look like new again with a coat or two of poly-u. The stuff is tough, but still have to keep hot pots/pans off of it.
PostPosted: Tue Apr 19, 2016 9:16 am
Beautiful table, nicely done. I'm glad the gussets ended up the way they did.
I rustic piece like this doesn't need no stinkin :-) flowy curves or bends.
Strong straight wood ( Baz. ) is how it should be.
Very very nice.
PostPosted: Tue Apr 19, 2016 2:08 pm
Thanks for the kind words, gents!
Perhaps I can sit at this table and imagine myself working on an actual buggy project again!?!? :shock:
PostPosted: Tue Apr 19, 2016 4:24 pm
Great job very nice :-)
Registered users: Bing [Bot], Google [Bot], Lanix, liduno, MSN [Bot], Q
