Nice find, running yet?
Consider just putting some fresh grease in the wheel bearings mine has over 10k miles on them and doing fine.
Details on the repairs would be a nice touch in case I have to perform them myself some day
Now mine has 10k miles I am replacing all the factory suspension bushings, need/want to pull the bed off and inspect everything real good, also need to find a take off factory skid plate.
I just separated the trans from the
Engine last night, and then gutted the rest of the trans. Its logically yard-sale'd in my shop right now, lol.
The (2) actual repairs needed here both required the Engine to be pulled were:[1] Starter bendix was stuck retracted, and
[2] eventually discovered the "high" drive gear to be broken + shaft damaged.
Well you can't get inside the stator case or trans box without pulling the whole Engine/trans/diff assembly.
Bendix repair was as simple as pulling the cover, pulling flywheel, replacing bendix and its 2 washers, installing new o-ring on cover, and sealing back up.
Trans repair required complete and utter tear-down to replace the main drive gear set & shaft. The trans kit was $539.99 and includes oil seals. They won't sell the gear I needed by itself (list price is $265), so they sell the whole kit. I see why though. When something in that set grenades, its will also affect the other parts include in that kit. Also good piece of mind.
While the entire powertrain unit is out, I'm also doing a couple of rzr-forum-recommended proactive fixes:[1] Rear pinion nut swap/loctite/torque. Its a well-known issue that the 08-14 rear diff pinon nyloc nuts do not stay put. Plenty of horror stories out there where the gears come loose & aluminum cases shred, costing a couple thousand dollars to repair. Requires some special non-standard tools that you have to make yourself (which I did) or borrow from someone else who made them. Replace the nyloc nut with an all-steel nut with 272 loctite and then torque to factory spec of 250 ft-lb. When I removed my nyloc nut, it came off with only 30 ft-lb (measured with torque wrench w/ gage). You can make this upgrade by only having to remove the bed and rear diff.
[2] Parking brake pawl bolt loctite and torque. Few stories (not as many as the pinion nut issue) where one of the (5) bolts back off, get caught in the main geartrain and grenade the main trans cases. The factory lightly torque steel bolts into the aluminum case without any thread locker. The fix essentially costs $0, but it requires a DEEEEEEP dive into the transmission.
Along the way I also found....[1] Rear axle bearings were shot, so replaced both front & rear set with Pivot Works branded parts. When I pulled the axles, both rear bearings were stuck to the hub and just looked nasty anyways.
[2] Side-posts on main frame under rocker panel were a little bent. Will straighten and hit 'em with rattle-can.
[3] PO sealed the clutch cover with some high-strength sealant, so I had to junk the old base plate and buy a new base & gasket.
[4] The middle #9205 bearing on the trans input shaft was a little "noisy", so replacing it.
[5] Needed a new belt
[6] Needs a couple light bulbs
[7] One of the rear diff axle oil seals was leaking, so replaced both
[8] Cleaned about 4-5 kitty-litter buckets + lots of shop-vac'ing hard mud out of this thing. The dude was having fun, broke, and basically parked it.
So far I'm in this thing about $4300-$4400. Cleaned out the $4k cash I got when I sold my Exmark mower plus wiped out most my Paypal account, lol. So still running on cash and haven't had to touch bank money. =)
I'm 10000% confident I'll get this all back together. My only worry is if there's something up with the Engine. I've never heard/seen it run. After the bendix fix was done, I hot wired the starter and the Engine rolls-over with what sounds like good compression. Didn't test comp yet. I've also removed the valve cover and everything looks super-clean; Engine oil is VERY clean and still golden translucent. Been a fast & fun learning curve, though!
Have to put a new radiator and p/s cooler in my Ram tonight, but planning on spending many hours wrenching the RZR back together this weekend. A lot of tedious clean-up and prep involved, too.
Trans action...
-Dan
