It is currently Thu May 15, 2025 2:18 am
PostPosted: Wed Oct 05, 2016 3:45 pm
Stop laughing.
I know I'll never find one on here. Not like anyone had one just sitting around but I had to give it a shot.
I need an input/driven clutch shaft for my 2003 Drakart extreme. Mine is bent.
I've contacted Drakart but haven't heard back yet,can't see them being much help.
So if you know someone who knows someone else who knows a guy who used to have one I'd be intrested. Lol. Now u can laugh. I am.
PostPosted: Wed Oct 05, 2016 9:55 pm
Contact Lin gear in Oregon,
Send them your old shaft, they can make you a new one, and even heat treat it..
I've had them make me gears for my quaif reverse box.
PostPosted: Wed Oct 05, 2016 9:57 pm
Here's there website.
http://www.linngear.com
PostPosted: Thu Oct 06, 2016 3:54 am
Thank you for the info and the link. At least I know if worse come to worse I can get one made. Now to cut off my old clutch.
Thank you again
Edd
PostPosted: Thu Oct 06, 2016 7:00 am
What did it run you to have you're gears made? I know every part cost will vary and if you have to ask you can't afford it but I was just curious.
Thanks Edd
PostPosted: Thu Oct 06, 2016 7:39 am
How the F did you bend it?...Was it like Beckham? :-)
PostPosted: Thu Oct 06, 2016 7:57 am
Came pre bent. Saved me the trouble.
PostPosted: Thu Oct 06, 2016 7:58 am
Yeah I just read your other thread.
PostPosted: Thu Oct 06, 2016 3:40 pm
Got the shaft out and took it to a performance shop here in town to straighten. It was off by .0035. Bent. Hope they can get it done.
PostPosted: Fri Oct 07, 2016 12:49 am
Thanks Edd
Inquiring minds want to know too ??
PostPosted: Fri Oct 07, 2016 4:14 pm
canadian oddy wrote:
Thanks Edd
Sorry for the late response.
I don't have the invoice handy but it was $138 each.
They were hardened all I sent them was the flange that came
From the box (so they could match the splines) and told them
What the tooth count was and chain type.
They fit perfect. I think I have pics someplace that was years ago but
I did contact the person I delt with recently (year or 2) to possibly
Have another set made.
Never went through with it though I sold the box.
But at least he said the price would he similar.
PostPosted: Fri Oct 07, 2016 5:26 pm
Thank you. That's not bad at all. If something goes wrong with them straightening mine I will be sure to use them.
I appreciate you're time.
PostPosted: Fri Oct 07, 2016 10:04 pm
Three thou!?
How did you know it was bent?
PostPosted: Fri Oct 07, 2016 11:58 pm
bullnerd wrote:
Three thou!?
That's kind of what I was thought.
Three thou could be bearing clearance.
PostPosted: Sat Oct 08, 2016 3:26 am
When idleing you could watch the driven clutch bolt wobble,that was my first clue.
I set the shaft on two Vee blocks and measured it. The closer you got to the middle the more it was off. Near the ends was .001 and went all the way to .0035 as you moved down the shaft. The worst bend was just inside the end of where the driven clutch would ride.001 is with in tolerance.
.0035 might not seem like much but at 7500rpms it is.
Guess I could have just half assed it and let the next guy worry about it.
PostPosted: Sat Oct 08, 2016 11:14 am
Ok, sounds good.
But if the bolt end is only running out .001 you wouldn't see the bolt wobbling around, its probably bent more than you think.
You cant mount the shaft between centers or V-block, you have to mount it similar to the way it mounts in the trans.
Are you selling it?
PostPosted: Sat Oct 08, 2016 12:06 pm
With both ends of the shaft supported by Vee blocks and set level I used a heavy based machinist height adjustable dial gauge set up. I took measurements every inch and marked the low side as I went. If the center is off .0035 that will show up on the end of the shaft.the further out you get from the bend the more noticeable it would be. If the shaft was only supported in the middle the wobble would be approximately 50% less but the shaft is supported on one end.
I'm not some bozo that doesn't know how to check if a shaft is bent. Even if I was unable to check it my eyes don't lie. A wobble is a wobble. And when it's enough to keep working the boomerang bolt loose it's too much.
No I'm not looking to sell. I'd want too much for it.
PostPosted: Sat Oct 08, 2016 12:09 pm
I thought you were trying to say it wasn't bent. I agree in a machinest hands the bend may be more.
PostPosted: Sat Oct 08, 2016 1:20 pm
I had more runout on my honeymoon night...AND still maintained WOT (Wide Open Throttle) for yonks with no damage to report and ended up with 4 healthy bratts! :shock: :-)
PostPosted: Sat Oct 08, 2016 2:12 pm
No, no, no, i'm not arguing with you.
I believe you and not questioning your abilities at all.
What I'm trying to say is, you have to support the shaft the way it is supported in the trans to really measure the runout.
Is it supported at both ends in the trans?
Support it where the bearings mount and then measure runout.
PostPosted: Sat Oct 08, 2016 2:57 pm
I might be too sensitive some times. I didn't mean to be snippy.
I took it to a local performance shop to be straitened. They do crankshafts so they said it would be no issue, but they made no guarantees which is understandable.
Said it would be Monday before they got to it. They didn't specify which Monday. Lol
I see what you are saying,I could have stuck the trans end in my mill and checked it that way ( not running) but it never crossed my mind.I'm no machinest, just a guy with a wide variety of tools and an active imagination.
I will keep that idea in my mind for future reference.
Registered users: Bing [Bot], FL670R, Google [Bot], Lanix, stix, wyeeoddy
