It is currently Fri May 03, 2024 3:03 pm
PostPosted: Sun Dec 03, 2017 12:06 am
Anyone ever use the needle fittings for their grease gun to grease pilot ball joints ?
PostPosted: Sun Dec 03, 2017 3:11 am
Yeah I have done that to my FL350's.
It does poke a very small hole so I did it from the back side.
I did it this way because I was to lazy to take the clips off and fill the boot by hand.
It would have probably worked better by trying to slip the needle between the boot and the shaft.
(oops there I go again talking about shafts)
PostPosted: Sun Dec 03, 2017 9:28 am
Okays, that’s what I did too
PostPosted: Sun Dec 03, 2017 8:01 pm
Or you can just remove them and do a thorough clean & grease. NAPA sells them off the shelf and they can be held on w super glue. Don’t laugh, it works. Done it and they still are holding. See this thread too - viewtopic.php?f=1&t=1701&hilit=Joints+Ball+Glue
Good luck
PostPosted: Sun Dec 03, 2017 10:13 pm
That’s a good idea what I did when I put new boots on mine was take off the old ones and got boots that are bigger then the originals and they are held down with the pressure of the spindle. No glue, no zip ties no clamps just for the force of the spindle pushing down
PostPosted: Mon Dec 04, 2017 11:57 am
You're correct, the pressure will keep them down however there may be a tendency for them to leak due to the constant movement of the the arms. At least the glue will keep the edges sealed up. Holds up amazingly well. Every time I've needed to do any work on the front end that requires popping the ball joints loose, it seems the boots get damaged/pinched/torn. For roughly $5 each, you can just scrape the surfaces clean and replace again.
PostPosted: Mon Dec 04, 2017 4:42 pm
next time I will definitely use your idea! it really adds a nice touch to the machine, looks factory!
Registered users: Bing [Bot], chorizofingers, Google [Bot], hoser
