It is currently Wed May 08, 2024 6:15 pm
 Post subject: Hondoo 670
PostPosted: Tue Sep 04, 2018 4:00 pm
Thought I'd start a thread.
I'm currently about what I believe to be 90% finished, at least where it is ready to ride, after putting in a new crank, honing the pistons I had it running over the weekend, now I've convinced myself to swap out carbs, I have 38 sbn watercraft carbs on now, man will be a giant pain in behind changing jets to dial this in, almost impossible to pull the carb off to get to the jets without pulling the RV plate off first. I have some 40BN carbs that are setup with the throttle shafts in line which puts the pump on the Engine side and the jet access plate to the back.
I have to make some custom velocity stacks so I can attach the air filters and the other thing is the pulse for the fuel pump is facing the wrong direction, I pulled out one of the 90 degree fuel line tubes from a junk carb and will be modifying one of my pump covers so the tube will be facing the Mag side.
 Post subject: Re: Hondoo 670
PostPosted: Tue Sep 04, 2018 8:26 pm
Don't leave us guessing ---------- Pictures ??
PostPosted: Wed Sep 05, 2018 3:23 pm
Ok, ok, thought I did on another thread
Here's one of the velocity stacks I'm making to fit the 40mm carb, the only ones I find to buy would not seal on the air filter boot, more to come, got to get to work
PostPosted: Thu Oct 04, 2018 3:46 pm
here is a heat shield I put together, hopefully it will keep the pipe from melting my seat
PostPosted: Thu Nov 01, 2018 4:06 pm
LT front end almost done, I've got to do the bump steer on it still, pictures to come.
What are others using for spring rate on the front, I am using some nice Olins shocks from a Cannondale Moto quad and it is sitting too high for my liking, I think I need to get lighter springs or maybe just the helper springs the shock has about 6 " of travel and as it sits it is only using about 1 inch, I'd like it to sit so the front end is about 50%
PostPosted: Thu Nov 01, 2018 8:59 pm
Looking forward to the ride report
PostPosted: Mon Nov 26, 2018 11:55 pm
Well, took it out to Glamis, did some jetting and didn't have to tow it so that's a good a good thing.
On the jetting, I've got a 2.0 needle/seat with the shiny silver spring, 75 pilot jet and 160 main with some opening on the low and high speed adjuster screws.
Front end is working pretty good, I put some ohlins shocks off my old quad, they seem to work, had to reduce the main springs to some 100/110# springs, still sits higher than I'd like
PostPosted: Thu Nov 29, 2018 5:10 pm
a little video for you
https://www.youtube.com/watch?v=dV8hiOPqifM
PostPosted: Thu Nov 29, 2018 6:26 pm
Kuma wrote:
I really like the sound of that Engine :-)
PostPosted: Thu Nov 29, 2018 8:16 pm
That thing looks and sounds wicked!!!
PostPosted: Thu Nov 29, 2018 10:44 pm
nice..sometimes wonder if I should of went that route instead of the 360 bv that I have
Registered users: Bing [Bot], Google [Bot], Kuma, Rppjr
