It is currently Tue May 13, 2025 11:55 pm
PostPosted: Tue Oct 22, 2019 2:57 pm
I cant remember the exact history of these wheels, but I had my paddle tires mounted to them that I used maybe 1 or 2 times a year when I had the Alabama Pilot. I pulled them out of the shed and tried to run them on my Dave-Co LT pilot on my trip to St Anthony in July, but the tire rubbed on my shock spring. They worked fine back on the Alabama pilot with fox air shocks, and I've never owned a stock pilot to say if they will fit or not.
These wheels are 10" tall, 9" wide with 4" backspace. 4/130 pilot/fl350 odyssey rear bolt pattern
SOLD
PostPosted: Tue Oct 22, 2019 9:04 pm
Your nails need clipping Matty! :-)
PostPosted: Wed Oct 23, 2019 11:00 pm
Yeah, I like to dig so they normally get worn down, but it's been cold out so I don't like to go outside ; )
PostPosted: Thu Oct 24, 2019 8:50 am
So would these stick out 1" or 2" more than the stock 10x8, 3+5?
PostPosted: Thu Oct 24, 2019 11:23 pm
That would be 3" of backspace on the stock wheels correct? If that's the case the added width of these wheels is 1" more backspace so it should be about the same as stock?
PostPosted: Mon Nov 11, 2019 10:06 am
Matt,
Are these still available? I'll take them if so. Just bent one of mine yesterday.
PostPosted: Mon Nov 11, 2019 12:20 pm
Come on Curtis... that’s an easy fix for you. Don’t get me wrong... buy them for backup but tackle that taco first
PostPosted: Mon Nov 11, 2019 3:45 pm
Yes that is the plan. When I get the wheel on the bench I’ll try to work it back with a bit of heat. I got it close with no heat at all so should be fine.
PostPosted: Tue Nov 12, 2019 8:09 pm
Sorry Curtis they just sold on ebay last night before I saw this post!
PostPosted: Wed Nov 13, 2019 6:20 pm
No worries. I am glad you sold them finally! I should have scooped them up from the get-go for that price.
Registered users: Google [Bot], Lanix, Q, redskinman, Rppjr, scpilot66, socalgii
