It is currently Thu May 15, 2025 11:08 pm
 Post subject: Comet 90D Driven
PostPosted: Sun Apr 22, 2007 5:49 pm
Here are pics of my 90D driven, any suggestions whilst I have it apart?
I assume the deep grooves are from dirt between the cam slippers and cam?
One slipper was missing, others are showing signs of wear.
PostPosted: Sun Apr 22, 2007 5:54 pm
When I installed this new I marked the face to see how far it shifts out.
Comet 90D Instructions http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=2052
Thanks Bill
PostPosted: Sun Apr 22, 2007 8:30 pm
The snap ring grooves wear on this clutch and it is important to put it back in the same direction that it came out - it should have a curved surface to it- I use a piece of 18 gauge wire and wedge it between the snap ring and the housing of the helix. With this and my adjusting shim/washer that fits inside the helix up against the snap ring and wire I have not had anymore problems with the snap ring coming loose and popping the clutch apart on the trail.
