It is currently Fri Mar 29, 2024 2:42 am
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Jan 14, 2008 10:29 pm
Hello drawing up a head for the pilot
2d first
speed
http://pilotodyssey.com/speedchaser.htm
here is the dome 49cc cnc machining
Part 1
Part 2
Thanks For Looking
SpeedChaser
12201-HE0-000 CYLINDER HEAD
File comment: the heads
File comment: layout of the stud holes
File comment: the over lay print out to see if I got the hole in right spots
File comment: the layout of water chambers
File comment: more drawing on the water chambers
PostPosted: Mon Jan 14, 2008 10:32 pm
the last pic for 2d will start 3d soon
File comment: fished with water chambers
PostPosted: Mon Jan 14, 2008 10:48 pm
Is looking good, like that hole spacing Honda invented?
PostPosted: Tue Jan 15, 2008 7:06 pm
Look at the water port layout
File comment: Here I put layout die on head and made a imprint on paper
File comment: Here I did and over lay from what I have drawn and the imprint
File comment: A pic of the light and setup
File comment: Drawn o-ring grove around out side
May not use. might go with stock head gasket
File comment: Before I go to 3d
PostPosted: Tue Jan 15, 2008 7:17 pm
Now going 3d
File comment: Here I have extruded the out side profile
And bored two holes in the center
File comment: Here I have cut out the water ports
And put all the stud holes in
File comment: Here I have cut out hole for socket stud nuts and put hole in center for the dome
File comment: Finishing up radius on top
Out side head all done
PostPosted: Tue Jan 15, 2008 7:34 pm
Now time to work on the center dome
File comment: Here I'm going to make a model
Of the in side of the dome
Filling hole with oil base clay
File comment: Here cleaned up clay with knife
so it's all flat and smooth
File comment: Here I have waxed up the inside of dome
Nice and thick this is so the bondo doesn’t stick to the dome
File comment: A Pic of the Mud
Shrinkage is about .005 per inch
File comment: Mixed and pored poke at it too get air bubbles out
Before it hardens
PostPosted: Tue Jan 15, 2008 7:43 pm
Next
File comment: sand down bondo
then sick in lathe and turn flat
File comment: put drill bushing plug hole to
drill a hole thru bondo mold
File comment: tapping hole in bondo for mounting
File comment: Setup on angel plate and started laying out the dome to find the radius
File comment: one more pic
PostPosted: Tue Jan 15, 2008 7:52 pm
Drawing the dome profile 2d the in to 3d
File comment: drawing one half of profile
File comment: Finished 2d half of dome
File comment: Getting ready to revolve the 2d profile in to a 3d solid
File comment: 3d dome added plug hole
File comment: All done next will be to cut one
in late feb 08
PostPosted: Tue Jan 15, 2008 8:01 pm
SWEET!
Once again you have out done yourself...
I have the bowl and squish dimensions if it would be easier for you to work with?
Once drawn can you use the cad to cc the volume of the dome?
The squish clearance will need adjusted if we go with using the head gasket, having owned both heads one with O rings and one with the gasket I lean towards using the gasket, the O rings can be a pain in the ass keeping in place while installing, sealing them was not a problem on my engines but I lapped the top of the cylinders before installing to ensure they were flat, if they are not flat and the O ring on the dome sees ANY of the flame it burns up the O ring, the gasket is more forgiving ...
PostPosted: Wed Jan 16, 2008 12:03 am
Very Nice!
Just curious... why do you make a positive of the dome rather than measuring off of it directly?
PostPosted: Wed Jan 16, 2008 8:38 am
Hello the reason was that I did want to scribe line in the dome it self
And this is the the old way of doing things
Yes I could of gust put in my cnc mill and use my renshaw probe
But not every body has one.
thank for looking SpeedChaser
PostPosted: Mon Jan 21, 2008 3:25 am
is there a way of machining the dome with a coventional machine. i want to make a head for the fl250 but the only way i could think about maching out a dome is by grinding out a tool with a radias. o i also need to draw up a blueprint for the head.
PostPosted: Tue Jan 22, 2008 1:25 am
You could cut the dome radius on a manual lathe with a radius cutting attachment. It would replace the tool post. All of them that I have seen are typically home made but there are some commercially made units available.
PostPosted: Tue Jan 22, 2008 8:10 am
yep that would work
have a look
www.bedair.org/Ball/ball.html
how to make
speed :-)
PostPosted: Thu Jan 24, 2008 12:57 am
Does anybody have a print for water cooled head. I think i could draw up my own. but i would be more comfortable using something that is known to work.I wonder if its worth buying a tool or making a tool. I might be able to borrow a tracer.
PostPosted: Fri Apr 18, 2008 8:20 pm
Speedchaser, did you ever cut any of these? I was thinking of making some, but would rather buy one from you!
PostPosted: Sun Apr 20, 2008 1:14 pm
Any updates?
PostPosted: Sun Apr 20, 2008 1:22 pm
I would buy one for the backup Engine..........
PostPosted: Sun Apr 20, 2008 3:42 pm
Count me in on one also
PostPosted: Sun Apr 20, 2008 4:29 pm
Me too-I would love to see this happen as well
PostPosted: Sun Apr 20, 2008 10:13 pm
Hello no as of yet I have not cut one . the time gose so fast around hear lately.
Will have some time to cut the out side of the head late this week .
Will have to get with Hoser on the bowl and squish dimensions.
Will post back soon
Thanks SpeeChaser
PostPosted: Thu Apr 24, 2008 12:48 pm
cut some parts today
File comment: stock for 6 heads
File comment: first side cut wow
File comment: next view of the bottom
note the radius in bottom
File comment: fixture for cutting the other side
File comment: mounted and ready to cut
File comment: it's cut
PostPosted: Thu Apr 24, 2008 1:01 pm
Looks great I assume the dome is next? :-)
PostPosted: Thu Apr 24, 2008 1:02 pm
with a brush finish
will try to get to the dome this weekend
my have some ready to go out late next week
thanks for looking
:-) Speedchaser :-)
File comment: with a brush finish
PostPosted: Thu Apr 24, 2008 1:09 pm
speedchaser wrote:
with a brush finish
thanks for looking
:-) Speedchaser :-)
Nice..
Can we get them personalized with writing of our choice on top? I would like PilotOdyssey.com on mine :-)
Registered users: Bing [Bot], canadian oddy, Google [Bot], Lanix
