It is currently Fri Apr 19, 2024 3:24 am
PostPosted: Tue Feb 26, 2008 9:06 pm
Hello for sale are custom billet Caliper Brackets
http://pilotodyssey.com/PO/viewtopic.php?t=3873
Aluminum 6061 are $90 each 4pc ready to ship
Aluminum 7075 are $95 each 4pc ready to ship
Custom steel rebuild able are $145 each
Will have new pic's later this week on steel bracket & slidder bolts kit
4pc will be ready 1st week of March
The shipping is free with in the u.s.a.
thanks for your time
speedchaser
File comment: top view
File comment: front view
File comment: botto view
File comment: steel bracket kit assembled with new style slider bolts
File comment: steel bracket spec. for bushings and rod wipers
File comment: pic of new steel bracket with new style slider bolts
PostPosted: Tue Feb 26, 2008 9:20 pm
I'll take a 7075
Mike
PostPosted: Tue Feb 26, 2008 10:52 pm
I would like to try a steel bracket
PostPosted: Fri Feb 29, 2008 12:18 pm
I will take a 7075 and a steal setup thanks. and nice work...............
PostPosted: Mon Mar 03, 2008 7:58 pm
-:: UPDATE ON QUANITIES :::
Aluminum 7075 are $95 each 2pc ready to ship
steel rebuild able are $145 each 2pc ready to ship
Thank You
speedchaser
PostPosted: Wed Mar 19, 2008 1:18 am
I received mine they look great thank you, what did you coat the steel ones with?
PostPosted: Wed Mar 19, 2008 8:25 am
Hello that is great. The steel ones where powder coat satin black
Thank you for your time
Speedchaser
PostPosted: Tue Aug 05, 2008 4:10 pm
Thanks but I stripped the thread in the caliper, not the bracket.....:(.........
Tim
PostPosted: Mon Sep 01, 2008 11:21 am
Hope you guys are still supporting SPEEDCHASER---these products are top noch and take time to manufacturer.
PostPosted: Wed Sep 24, 2008 3:03 am
Really nice work. Do you still have any or these left> one of mine still works but is ratty as can be. Looks like you are a step away from making a FL350 Caliper, With these machining skills you have. I would think a version without the E brake would be easy and land you some dough too.
PostPosted: Thu Oct 02, 2008 9:54 pm
Recall Pilot rear caliper bracket
speedchaser
Hello All
Got some Bad news on the pilot rear brake bracket I got the info from pilotnut(( thank you for the info))
1st When he try to install the 6061 and the 7075 aluminum bracket it hit a web on the transmission
2nd 6061 / 7075 / custom steel I found that the disk on the pilot is thicker then the fl350. So there is less
clearance on each side of the disk then the stock bracket . ((It will fit but it has less clearance on each side of disk.))
so the people that purchased a brake bracket for a pilot please PM me so I can fix this problem for you
Sorry for the inconvenience
Thank you SpeedChaser
PostPosted: Thu Oct 02, 2008 10:18 pm
Thank you Jeff for taking the time and effort to solve a HUGE problem for the POOA community (that of parts becomming discontinued by Honda).
Also - I want to commend Jeff on doing everything possible to address and correct the issue I had with the bracket as quickly as possible.
Someone who firmly stands behind his products and provides exceptional customer service is someone who should be recognized as it seems harder and harder to find these days.
Pnut
PostPosted: Sun Oct 05, 2008 10:07 am
PM sent and THANKS for standing by the products you sell.
PostPosted: Thu Sep 03, 2009 1:44 pm
Where do I go if I want to order one.
PostPosted: Mon Jul 05, 2010 2:25 pm
Im in need of a steel bracket setup.
PM sent
PostPosted: Tue Jul 06, 2010 10:10 am
viewtopic.php?t=7537&postdays=0&postorder=asc&start=0
PostPosted: Sun Feb 20, 2011 4:25 pm
SPEEDCHASER
I am looking for caliper bracket and bolts.
PM sent
Eagles17
PostPosted: Thu Oct 11, 2012 1:58 pm
Just got mine and its VERY NICE. Nice workmanship.
PostPosted: Sat Dec 21, 2013 7:08 pm
speedchaser Are you still selling these for the FL350?
PostPosted: Sun Dec 22, 2013 11:01 am
what ones i have aluminum and steel
speed
PostPosted: Tue Mar 11, 2014 5:35 pm
SPEEDCHASER
I am looking for caliper bracket and bolts.thanks!!
PostPosted: Wed Oct 08, 2014 7:31 pm
I need a caliper bracket, 6061 aluminum please or whatever is available.
Do you still have any?
PostPosted: Sun Dec 07, 2014 10:49 am
Speed you have any Pilot brackets available?
Don't dare so NO! :-)
PostPosted: Mon Dec 08, 2014 5:05 pm
Pardon my ignorance here but this is an old thread (2008) that keeps getting revived year after year as you can tell by the posting dates. My question is obviously people need these and someone here (speedchaser) is obviously talented enough and willing to provide them, but what am I missing. Why do you need them ?? How the hell do you bust them ?? Do they wear out ?? I am confused.
PostPosted: Mon Dec 08, 2014 7:02 pm
Yes they wear out in the sliding pin areas,plus in the brake rotor slot.
I've had 2 calipers where a hole was worn right thru between the rotor slot and sliding pin.
Depending on your riding ground conditions,sand,rocks,general crap get ground into that slot area/notch and eventually wear thru to the sliding pin hole.
Then the crap enters the pin hole and wears that out too! Aaarggh!
A better way of shielding/protecting that area needs to be addressed.
I fixed up one calliper by rolling my own bush around a suitably sized drill bit shank, from a thin polished sheet of stainless steel.
The SS sheet was just scrap from a kitchen flue,worked perfectly,but everytime I've tried to fix/fill the rotor slot hole,it does'nt last long.
I have lots of pics of it in my threads,maybe the FL800/AC550pilot thread? I'll look.
