It is currently Sun May 19, 2024 1:02 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Mar 30, 2008 8:07 pm
more
PostPosted: Sun Mar 30, 2008 8:10 pm
that's it for now, Baz I started maping the bars.
PostPosted: Sun Mar 30, 2008 9:17 pm
wow, what got loose and pounded around in there?
PostPosted: Sun Mar 30, 2008 10:26 pm
Big end bearing parts look at the cank pic where it blued you will see where the shime started to flake from the heat. The bearing is trash and maybe event the crank When i get it apart I will see if can be rebuilt. No matter got new one in box. and one already rebuilt.
PostPosted: Sun Mar 30, 2008 11:30 pm
When my lower rod bearing let go last year in the 420, it blued the crank just like that. Sorry to hear but at least you already have a good crank ready to go(glass half full thing). Is it rebuilt or a used crank? Good time to swap main bearings and seals(while the cases are split). Call it a $100 insurance policy!
PostPosted: Mon Mar 31, 2008 7:50 am
Do you have the bottom end split yet?
Look at the cases in the bottom end did the rod hit the cases?
PostPosted: Mon Mar 31, 2008 3:35 pm
Half full that's me. I have both new and a rebuilt on hand with new bearing and seals. I split case on every rebuild and replace beaing and seal and measure crank as well look over the big end. I run hard and don't care to do twice if I can keep from it. The rod did not hit case It locked up before it got that far. The run out on crank will tell the story there. I will measure before pushing in apart. She the wife has bragging rights " it locke up chasing the tigers".
PostPosted: Mon Mar 31, 2008 3:59 pm
Any machine marks left on that piston?
don't look like much bevel left around the ports?
What port mods you planning on making?
PostPosted: Mon Mar 31, 2008 4:19 pm
Hardly any left, bore and piston wore but good. I posted end gaps,bore and forgot piston I measured but forgot to post sorry, and they were at there max and beyond. She got good time out of it. Shame I did nothing until it siezed. Please feel free to smake me around. This cylinder will be bored a fitted with .50 honda as well as a few more port mods and be held for spare. I have learned a thing or two since it was touched back in 97 yes 1997. The new cylinder will get a new whole set of upgrades power and a little rev porting The Cr will be adjusted to cylinder volume at exhaust closing to match stock pipe with altered stinger dia. I thought I would try something new there. Yhe Bemp will be set after the CR is calculated and exhaust duration is calculated. That will part three math working on part two now. I,am maping the duration in degrees to calculate the port pramerters and carb size. I wil post more pics as I take them. Feel free to throw thing out there I,am open minded. I have an alternive thery to share on next write up. I did how ever post some info on running low compression I guess I should have read what I wrote. I do need to alter post I forgot a couple of good points. You will get a kick out of the bottom end pic. The resadue left behind from exhaust gase were the worst I ever seen. She had to be on it hard when the rings could no longer hold back the pressure. Can we say FLLLUUUTTTEEEERRRR. The syn resadue really left a mess as it seperate from the fuel.
PostPosted: Tue Apr 01, 2008 11:58 pm
case splt pics
File comment: spilt and pushing crank
File comment: removing seals
File comment: removing other side attaching splitter to push bearing
File comment: seal abd bearing kit
PostPosted: Wed Apr 02, 2008 12:10 am
more it keep timeimg out
PostPosted: Wed Apr 02, 2008 12:14 am
it get better
case splitter with seal,clutch side bearing tool.JPG [ 64.09 KiB | Viewed 3095 times ]
PostPosted: Wed Apr 02, 2008 12:20 am
more fun.
File comment: pulled bearing Japan
PostPosted: Wed Apr 02, 2008 12:24 am
some clean time on surface
PostPosted: Wed Apr 02, 2008 12:32 am
If you look over the crank pics you know why I can not measure run out. It will not run in blocke to accurately measure. The rod is locked in pritty good. I will have to push apart to check. The old crank bearing look preaty good. I will clean and lookover a keep for bench motor (( Internal Combustion Engine ? )) if good. The stator side looks the worse. The gear case was full of oil I cc the drained fluid to make sure the seal was holding. The bearing were tight in the case and on crank. No spinning. Good sign for new tight fit. I will finish clean up now I now cases are good. I will measure run out on new crank since box was beat up. The packing was to be desired Time let Honda know. Kawasake at least foam packs theres. I will also mic old and new bearing and after case cleanup measure case.
PostPosted: Wed Apr 02, 2008 12:41 am
Great inventory of tools, we'll have to start calling you "Adnoh the Tool Man" Arrrgh Arrrgh!
PostPosted: Wed Apr 02, 2008 8:11 pm
I like tools like I like new parts. Have any thought on what I can add. Stixs, Tobey and I are probley going to make our way to OKC in two weeks. You be around. I will need something to do while the Wife and Mother in law shop. Do some jetting, shoping of our own. Carbs tires rims ect. I just hate to be there driver when I can be playing. I could even load up the 450 for some odysse chasing and bar banging. Remington park is calling Tobey and My name Man they have great jumbo shrimp. Watching the quarter horses remind me of the tiger comming out of the hole I bet it would even be a photo finish between Drakman and Tedpilot. I would lay down some cash on that one.
PostPosted: Wed Apr 02, 2008 8:55 pm
I think you have them all. No plans in 2 weeks.I'll be pulling my pipe to get the old EGT probe hole filled and repositioning the probe this weekend.I got a compression gauge:) Maybe we can tinker and then play with the toys.
PostPosted: Wed Apr 02, 2008 9:35 pm
I like to tinker. You could just brase the hole shut. Yu can get a cheap kit from farm and ranch supply two small botles and a few stick to brase with. Or mabye just brase patch over as not to alow build up inside distorting the flow ( bumped surface) probly wondnt hurt, patch would be easier. What about a screw insert to reatach if needed then it could be caped. Just throwing thing out there. Any thought on where to relocate the probe.
PostPosted: Wed Apr 02, 2008 11:55 pm
Throw all U want, I'll catch.I've never brazed and not sure how, patch on inside or outside or both?. I thought about the screw thing but like you said I didnt want to leave any "imperfections" inside the pipe. I was going to take the pipe to my welder guy who is also an automotive exhaust system installer, have him weld a disc inside the hole to fill it in then we can slip some kind of rotary file or equivelent inside the pipe to smooth it out, though 6 inches is quite a ways to be reached with a pneumatic rotary file, Im sure Ill figure something out.Who knows maybe I will get to buy a new tool to do the job, Arrrgh, Arrgh.
Randy at Ody Sal has never steered me wrong, he says probe should be 2-1/2 inches from head and the tip of the probe should be just shy of 1/8" of center of pipe,Turbo and another guy said thier probe was about 3 " or just inside the 2 springs.
How does this sound to you. Do you think the brazing would be better...Your turn...
PostPosted: Sat Apr 05, 2008 11:49 am
Not know about EGTs does to type of pipe have an effect on location. I would like to read more location to type of pipe. I bet "H" would good info on that or link you to it. Have you made any jetting changes and seen an effect on egts.
PostPosted: Sat Apr 05, 2008 11:54 am
No jetting changes yet. Randy suggested the proble placement specifically for stock pipe.
PostPosted: Sat Apr 05, 2008 4:38 pm
I think Digitron states 6" from piston wall???
PostPosted: Sat Apr 05, 2008 4:43 pm
That sounds right Turbo. . I just measured from the piston wall and that comes out to 2-1/2 inches from the end of my pipe
PostPosted: Sat Apr 05, 2008 5:45 pm
Stixs used that new tool yet. What's the readings. Why the pipes off take a look inside. Piston skirt and cylinder walls. So does the pipe make a diff on locaton or not. Just wondering. I measured up bottom end and ready to assemble. Heres a couple of run pics on crank.
